Old 02-12-2007, 12:16 PM   #1
1973 23' Safari
Maryville , Tennessee
Images: 13
Axle Replacement on Safari 23
I am about to start looking at new axles for my 73 Safari 23 Footer. It currently has the tandem axle set up with 2600lb axles. Any suggesions on what I can increase the rating to? Also what measurements do I need know? 12 Inch or 10 Inch brakes?
Thanks in advance...
kneal is offline   Reply With Quote
Old 02-13-2007, 05:54 AM   #2
Somewhere , Indiana
My thoughts.
Kneal,
I'd go with 2800 - 3000 pound capacity but no more.
Additionally, I'd go with 12" brakes.
Check the axle manufacturer websites for an order form to be sure what dimensions are required.
Best Regards,
Henry
axleman is offline   Reply With Quote
Old 02-13-2007, 06:00 AM   #3
1973 23' Safari
Images: 13
Great.. Thanks Henry. That is very useful information.
Old 02-13-2007, 06:14 AM   #4
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
If you haven't yet decided on a source of supply for the axle I can suggest, tandrtrailer.com. I have done business with Rich and been very satisfied with his service. He is knowledgeable about the trailer axles, both torsion and leaf spring. I have found that their prices to be competitive and they do excellent work. When I visited their shop it was busy, tidy and clean. I have no affiliation with T and R other than being a satisfied customer.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 02-13-2007, 08:16 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
kneal,
Your axles are torsion axles and that would be the best thing to go back with. Use the search feature and you can read for days, on the various pros and cons of increasing the weight rating and what axle to use. Your trailer came OEM with Henschen axles. However other people have been successful in installing other brands. Dexter also makes a good axle but you have to be careful ordering them as there are many possible combinations and not all Dexter dealers are up to speed on them.
Aaron
WBCCI #XXXX AIR #2495
Old 02-13-2007, 09:11 AM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Axels again
As the Sergeant on "Hogans Heros" said........"I KNOW NOTHING...I KNOW NOTHING." (this will keep the thread alive.)
Name:	66 New Axel.jpg
Old 02-13-2007, 10:00 AM   #7
Images: 59
Kneal,
Why are you increasing the axle weight?
It just sounds to me like 2-2600# axles would be more than adequate for a 3500# trailer.
Old 02-13-2007, 10:05 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by markdoane
...It just sounds to me like 2-2600# axles would be more than adequate for a 3500# trailer.
they would be. but this is a 5800lb gvw trailer.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 02-13-2007, 10:13 AM   #9
Images: 59
That makes sense. I didn't see that bit of information. I'm looking at the 'trailer weights' spreadsheet for a '73 23' Safari, which lists a dry weight of 3450#, and tongue weight of 590#.
2-2600# axles + 600# tongue weight = 5800#. Still adequate?
Old 02-13-2007, 10:15 AM   #10
1973 23' Safari
Images: 13
I have added some weight due to an interior remodel with real wood as opposed to the plasticy wood. Therefore I thought if I could move to a 3,000lb axle, then I would.
Old 02-13-2007, 10:22 AM   #11
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
You can move up a little and it's a good idea since you are changing them anyway. Stay with torsion axels but remember when it comes to weight you still need to stay within the limits of the trailer frame, tongue and tongue weight and something everyone forgets, keeping the balance ratio correct.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-13-2007, 10:29 AM   #12
Go with 12 inch brakes and no more than 3000 pounds torsion axle capacity.
With the added weight, you should be about as perfect as you could ask for.
Also, keep in mind, having balanced running gear will enhance the overall performance.
Old 02-13-2007, 10:36 AM   #13
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Is that the pdf on airstream's website? its incomplete...some years, it shows emtpy weight...others, gvw...
but anyway, yeah, 2x2600+600=5800...that's the way the factory built it. What that pdf doesn't show is that there was also a single-axle version, which has a much lower gvw...
they had a whole lot of cargo carrying capacity back then...I can't imagine carrying 2000lbs of gear with me to go camping...even if you include the weight of my spare tire, propane, water, and an air conditioner. So even with some heavier cabinets, its still probably ok....but if you can get a little extra capacity without losing anything in the process, why not?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 02-13-2007, 10:38 AM   #14
Images: 59
We're on the same page, but I think 2000# NCC is more than enough to allow a little extra cabinet weight. I just don't want to see Kneal end up with a 'hard riding bronco' because the axles are too stiff.
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
re-plumbed '67 Safari tod47d Plumbing - Systems & Fixtures 4 01-30-2006 11:04 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
