Old 12-18-2007, 10:46 PM   #1
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
What is the axle replacement process for a 1963 single axle Tradewind? Is there a direct bolt on replacement available?
Is the original axle a Henschen?
Is the preferred replacement axle Dexter or Henschen? I will need to install myself since I live in Indiana (a long way from Calif.). I do have a vintage Airstream dealer nearby (Vintage Campers) if I need some assistance.
Mike Brumback
Grand Master is offline   Reply With Quote
Old 12-18-2007, 10:50 PM   #2
1970 31' Sovereign
Collierville , Tennessee
Mike Brumback
Is the 63 a leaf or torsion axle?
TN-TUNDRA is offline   Reply With Quote
Old 12-18-2007, 11:58 PM   #3
1963 24' Tradewind
Torsion. Specs indicate it is a Dura-Torque. Is Dura-Torque made by Henschen?
Old 12-19-2007, 05:47 AM   #4
Dura-Torque axles are made by Henschen.
From 1968 and back, mounting a Henschen axle requires drilling three 1/2 holes through the axle mounting bracket and through the axle mounting plate.
This eliminates the need to extend the axle mounting plate downward. When the new axle is positioned within the axle mounting plate, it automatically aligns itself.
Install the grade 8 hardware, and the job is done.
There are numerous variations between California and Ohio built trailer fom 1968 and back, regarding wheel well clearances, that require slightly different locations for the shock brackets.
Therefore simply install the new brackets in the same place as they were on the old axle, and it's done.
Old 12-19-2007, 07:35 AM   #5
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Mike Brumback
Sorry, no direct bolt on replacement for a '63. Your replacement will require drilling regardless of manufacturer. Do a search on axle threads for price and ease of installment comparisons. Good luck.
Mr replacements:
http://www.airforums.com/forums/f437...nts-34646.html
A recent Dexter replacement:
http://www.airforums.com/forums/f437...led-38072.html
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 12-19-2007, 12:47 PM   #6
2005 30' Classic
Images: 12
Installation of the new shock brackets means you must weld them in place.
GetOutDoors is offline   Reply With Quote
Axle replacement part II Rhonda Axles 37 03-12-2009 06:04 PM
Another Axle Replacement The Flintstones Axles 6 09-06-2007 12:38 AM
Axle Replacement (60's Vintage Airstream) pfefferd Axles 2 05-21-2007 04:08 PM
Axle replacement Pick Axles 92 02-18-2006 08:27 PM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
