Originally Posted by nrgtrakr
The best I can tell from the data plates on my axles is they are original (75). The torsion arms however are slightly positive (down). I measured wheel to wheel well before lifting, then again once it was up in the air, 1-7/8", so they don't meet the 3" guideline.
As with the Pirate's Code, the 3" thing is "more of a guideline...." The Dexter axle specifications say that the difference in the distance between the spindle center and the frame (should be the same as the difference in the distance from the wheel to the wheel well) from no load to full load is right at 2.25 inches. My axles were more like 1.75 inches when I replaced them. It made a difference in the ride that I could feel from the truck.
Al
