Old 01-01-2003, 08:45 AM   #29
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I'll try and clear up some of this confusion.
First, Henschen makes axles, not brake backing plates, and brake parts. Dexter makes the OEM backing plates and brake parts, and supplies the hub/drums to Henschen.
My axles came with the shock mounts welded on, and also a neat little clip to hold the brake wires.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-01-2003, 08:56 AM   #30
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
I probably didn't need to buy this but...
Here is a neat tool I got from tooldesk.com for repacking wheel bearings. I am going to use Amsoil synthetic grease when I do mine.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-01-2003, 12:42 PM   #31
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
All you do is place the bearing in the packer, they put the cap on and apply pressure. The old grease is forced out and replaced with the new grease.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-01-2003, 12:51 PM   #32
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
You can save some money...
By buying "bare" axles without the brake plate and hub/drums. That is how I bought mine. I just pulled one of mine off today. Well, I think I made the right decision. My drums are in great shape, and so is the backing plate and it's components. I saved $300 an axle this way. I hope the the other 3 are in as good a shape as the 1st one! I do have the round magnets instead of the new oblong style. I am not going to replace them, they are fine and the trailer stops fine. Drums have no ridges and are smooth. They look a little rusty in this picture, trailer has not moved since the last week in September.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-01-2003, 12:54 PM   #33
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Here's what I saw after I pulled the tire off. A tire that is 10 years old!! New set on order. I've got new shocks, of course. You can see this one leaks. Don't worry, I do have jackstands!
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-01-2003, 03:34 PM   #34
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
Smile Horizontal shocks
Nice photos Pick!
Now I see what Inland RV meant when they asked me if my shocks were horizontal or vertical. Mine are vertical and so my axle came without the lower shock bracket welded on. Anyone ordering an axle where the shocks mount horizontally like yours gets an axle with the bracket already welded. That's to your advantage and savings, but I wasn't as lucky.
Forrest
Forrest is offline   Reply With Quote
Old 01-01-2003, 03:45 PM   #35
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
knowledge
"They asked me for a number of specs, and measurements that I had no knowledge of. "
i'd guess that's worth about 500 bucks...
john
Old 01-01-2003, 04:36 PM   #36
Chas's Avatar
Images: 22
John,
I guess if I needed 2 axles it would be worth a $1,000???
Chas
Former Airstreamer
Chas is offline   Reply With Quote
Old 01-01-2003, 07:37 PM   #37
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Off topic posts removed.
-BobbyW
BobbyW is offline   Reply With Quote
Old 01-02-2003, 08:57 AM   #38
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Forrest
After it was all said and done are the new axles a big improvement? It the ride difference noticeable, smoother etc?
Ken J is offline   Reply With Quote
Old 01-14-2003, 12:17 AM   #39
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
Smile Ride
Well, yes the towing is better. This is a subjective judgement though, and I can't say that simply replacing the axle made the difference. I have new shocks, wheels, tires as well as the axle. Altogether I think there is a significant improvement, but the biggest difference is in having peace of mind.
Old 01-23-2006, 11:48 AM   #40
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I ran into a guy up in Yellowstone who said he got two new axles from an outfit (Axis) in Elkhart IN for about $750 for the pair. New as in completely new, including the square tube crosspiece.
Old 01-23-2006, 11:52 AM   #41
1975 31' Sovereign
1977 23' Safari
Oops. see #40. Axles included the brake backing plates for that price--I don't know about drums. I haven't been able to confirm, yet.
Old 01-23-2006, 04:44 PM   #42
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Im that guy
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Axle replacement finished uwe Axles 55 11-05-2011 10:21 AM
POLL: Axle Replacement Safari Tim Axles 45 01-30-2006 09:02 PM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 08:04 AM
