Old 09-18-2016, 09:39 PM   #1
CabMan
1960 22' Flying Cloud
Sunlakes , Arizona
axle replacement
I hear everyone talk about axle replacement I have a 1960 Flying cloud with a single axle, haven't really had it one the road yet only to tow it from where i bought it about 10 miles from home and on surface streets. So how do you know if it really needs the axle changed out
cabmike1954 is offline   Reply With Quote
Old 09-18-2016, 10:29 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The axle replacements you are "hearing" about are a torsion spring axle. The springs are inside the axle.
Your 1960 unit likely has leaf springs. Replacing the axle on a leaf spring suspension would be needed ONLY IF the spindles have been damage. Since the springs that do wear out over time can be replaced independently of the axle. (Springs of any type only have a life of about 10 to 20 years) You would only need to replace the leaf spring pack on a leaf spring suspension arrangement.
>>>>>>>>>>>Action
Axle replacement / Floor Replacement - Newbies! toesonoz Vintage Kin 12 07-02-2016 05:05 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
