I would recommend that you go nuts with the angle. Put in as much as your heart will dare to. The additional height on mine required a change in the step I use but I don't regret it a bit.
Be ready to modify your axle, I had to change the shock mounts to get the clearance from the frame. They don't build them like they use to, or they don't know what the exact configuration was at the time. I understand the configuration changed quite often.
Peace
Gary
