Old 05-09-2013, 05:52 AM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Axle rating and max cargo weight?
Hi everyone, two questions.
1)What is the weight rating on the axle of my 1959 24' Tradewind?
2) What is the GVWR (or max cargo weight) of this same trailer? Pic of the axle attached. Steve welcome to our airstream story - home
steveirving is offline   Reply With Quote
Old 05-09-2013, 07:12 AM   #2
SteveH's Avatar
Common Sense , Texas
Don't know if it's there on a 1959, but the newer trailers have a ID plate actually on the axle that states the max capacity of the axle.
In the absence of that plate, and all other manufacturer's specs, I would suggest you check for hub and bearing capacity by cross referencing part number data.
Regards,
Steve
Old 05-09-2013, 07:15 AM   #3
Don't really have a printed answer, but if you decided to upgrade to a torsion axle, you would install either a 4500 pound or 5000 pound rated axle.
Old 05-09-2013, 09:19 AM   #4
1959 24' Tradewind
Quantico , Virginia
Images: 11
I guess im trying to confirm what the weight rating of the original stock trailer and axle was/is? Original 1959 dry weight was 3200 lbs. after ac and fridge and upgrades over the years it is now 4000lb. What were the stock single axles rated for?
Old 05-09-2013, 09:28 AM   #5
I just located an old chart that has a bunch of numbers for the old trailers.
A 1959 24 foot Airstream, had a dry weight rating of 3170 pounds.
Also in the same year, there is another weight rating for the same trailer of 3275 pounds.
I would believe that the difference depends on which plant built the trailer.
The chart does not state which plant.
Old 05-09-2013, 09:48 AM   #6
1959 24' Tradewind
Quantico , Virginia
Images: 11
So are these numbers you found the dry weight, the allowable cargo weight, or the max weight for the whole thing?
Old 05-09-2013, 09:54 AM   #7
Images: 59
The original axle on my '59 Tradewind was a 3500# Hadco axle. However, it was a round axle, unlike your square axle.
I replaced it with a 5200# Dexter 4" drop axle, and upbuilt the leaf springs to handle 4800 lbs.
Old 05-09-2013, 09:55 AM   #8
The chart says "dry weight".
Old 05-09-2013, 10:05 AM   #9
1959 24' Tradewind
Quantico , Virginia
Images: 11
Dry weight should be the total trailer weight minus water, food, fuel, and waste.
Old 05-09-2013, 11:02 AM   #10
1981 31' Excella II
New Market , Alabama
Whatever the specs are there is a chance that your old axel is weaker than spec due to age. Older axel spindles have been known to break which you really don't want to happen. Replacement axels are available from places like tractor supply and Northern tool or any trailer place. I like the simplicity and maintainability of conventional axels. I don't know if your axel is a special Airstream specific item or not.
Perry
Old 05-09-2013, 11:35 AM   #11
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
Steve,
All new running gear would be my advise. Especially after all your work on such a great looking trailer.
I wouldn't trust the old spindles or brakes. Even with the rebuilt springs.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-09-2013, 12:43 PM   #12
1981 31' Excella II
If you really wanted to keep your old axel you could have it tested for cracks but that might get expensive.
Perry
