Old 10-08-2004, 12:05 PM   #1
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
Axle rating
I have a 34' '83 Limited with three axles. Are the axels on tthe current 34' 2 axle heavier duty? Point being if I needed to replace m axels with the new ones would the unit have more load capacity?
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 10-08-2004, 12:52 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
The 34' are still 3-axle trailers. The 30 and 31 are the longest 2-axle units.
There are several heavier axles available than you probably currently have. There is a 4400# axle on the 30' slideout and a 5000# axle on the Canadian 30' slideout. The plain 34' has 3200# axles and a 34' slideout has 3500# axles. These numbers from the Classic parts book.
However, I wonder whether the axles are the limiting factor. The frame may well limit you on an older unit before the axles do. The current slideouts undoubtedly have a beefed up frame.
John W. Irwin
WBCCI #9632
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Axle Question drex Axles 7 07-30-2007 05:50 PM
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Sorry. Another axle question whistler Axles 6 08-28-2004 10:33 AM
'69 Ambassador-Org. axle rating 1stimer Axles 4 11-24-2003 10:58 PM
