Old 08-06-2015, 02:16 PM   #1
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
axle questions
I have a 69 safari that has a replacement axle. I would like to re-pack the wheel bearings and perhaps by replacement bearings, but the tag on the axle is worn away and I don't know what information I need in order to do these jobs or where to find this information. Can anyone help? Also should I jack up the A/S and remove the wheels for the winter or not? your thoughts! Thanks.
tracker is offline   Reply With Quote
Old 08-06-2015, 02:23 PM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Remove the existing bearings and inspect. If they look good, simply repack. If not, you should be able to get a part number off of them in order to get correct replacement bearings. Most auto parts or trailer shops will have the ones you need.
BambiTex is offline   Reply With Quote
Old 08-06-2015, 03:41 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I leave my wheels on and just park for the winter. Ditto clening a bearing and a seal and takng it to a auto parts store to match up numbers. The numbers are small and the parts people know what to look for.
Old 08-06-2015, 04:23 PM   #4
Posting the bearing numbers and the grease seal number, will help identifying the axle.
Torsion axle equipped trailers, if being stored for an extended time, should be placed on jack stands, so that "ALL" the weight has been removed from the tires.
Old 08-06-2015, 05:30 PM   #5
Sioux Falls , South Dakota
"Torsion axle equipped trailers, if being stored for an extended time, should be placed on jack stands, so that "ALL" the weight has been removed from the tires." What about a full-timer who is staying in one place for several months? Jack stands or not?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 08-06-2015, 10:37 PM   #6
tracker
tracker's Avatar
1969 23' Safari
Andy how do I tell if I have a "torsion" equipped axle?
Carl
Old 08-06-2015, 11:57 PM   #7
Southwestern , Ohio
Andy how do I tell if I have a "torsion" equipped axle?l
Any Airstream built since about 1962.
(But I have never jacked up our trailer for storage. It's never really in "storage".)
Nuvite-F is offline   Reply With Quote
Old 08-07-2015, 08:44 AM   #8
Mission , Texas
The bearings may not need replacing. If the metal is discolored, then absolutely replace them. As with most replacement parts, taking the old ones to get new sometimes saves trips. Also best to replace in full wheel sets.
More on axles here:
http://www.inlandrv.com/articles/dur...xle-92001.html
There is also a YouTube from Dexter:
I seem to remember Andy once saying 25 years life expectancy for axles.
Using a 4 ton floor jack to get it up in the air, my 75 is currently sitting on four 6 ton jack stands. Funny part, not sure if it will remain, but the measurement from wheel to wheel well has increased 1/4 inch in the last couple of weeks. Axle fountain of youth?
nrgtrakr is offline   Reply With Quote
Old 08-07-2015, 10:31 AM   #9
Carl
Carl.
Look under the trailer.
If you DO NOT see any leaf springs, then you have torsion axles.
Also, Airstream has used them on every trailer they have built, since 1961.
Another thing to look for, is an arm that goes rearward from the axle tube that has the brake backing plate attached to it.
Old 08-08-2015, 06:29 PM   #10
tracker
tracker's Avatar
1969 23' Safari
Thanks for all info it answers several questions. Carl
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
