Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 08-21-2009, 07:42 PM   #1
Profile:  1965 20' Globetrotter
Fairfield , Connecticut
Axle question
I am getting started on 65 Globetrotter project and am looking at the axel.
Tried the 3" test and scored about 2. After removing the hub to get a better look at things. I applied pressure to the swing arm, the travel was only 1/2" before the trailer started to lift. Is the 3" all in the swing arm or does that include any tire / shock compression? Any comments? Jim
ID:	85839   Click image for larger version
JLGT5107 is offline   Reply With Quote
Old 08-21-2009, 07:55 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
It's for the spindle/hub only, tire flexing doesn't count. If it did, all you'd have to do is lower the air pressure to be "good".
(No Longer at Inland RV)
Old 08-21-2009, 08:15 PM   #3
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Yeahbut, wouldn't that save everybody a lot of money?
BTW, how's the weather in Texas? We miss you in So Cal.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 08-21-2009, 08:17 PM   #4
Thanks Terry , that was my assumption. I just havent seen any posts that go beyond the "tire drop" test and the angle of my swing arms does not appear too far off what most illustrations indicate as in the "acceptable range". This suggests to me that the angle of swing arm is not a reliable indicator of axel condition.
Old 08-21-2009, 09:20 PM   #5
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
With only that amount of travel and being a 65 U can pretty well figure that the rubber rods in that axle are solidified. I changed axles last yr and it made a HUGE difference in how the trail rides and handles.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 08-22-2009, 09:48 AM   #6
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
I replaced the tandem axles on our Trade Wind last Spring. Great improvement with less tossing of 'stuff' in the coach (except our recent ride on 680 north of San Jose!) and noticable towing smoothness. Worth the expense and easy to accomplish. New Axle Installation; '66 Trade Wind
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
Our Rig
Sept 2009
1966 Trade Wind
455 cid
Old 08-22-2009, 05:27 PM   #7
Thanks all. The axel replacement was assumed prior to purchase , so I mainly wanted to bring up the point that the gear appeared to be moving
when in fact the axel is frozen. Nice pics on the axel replacement, I'll be referring to them soon. Jim
another axle question ClayandPerry Axles 2 12-14-2007 05:24 AM
Axle Question drex Axles 7 07-30-2007 06:50 PM
Another axle question wannaroam Axles 16 10-12-2006 09:17 AM
Sorry. Another axle question whistler Axles 6 08-28-2004 11:33 AM
axle question stp2136 Axles 1 10-05-2003 08:05 AM
