Old 01-26-2012, 05:41 AM   #29
1981 31' Excella II
New Market , Alabama
Well I have a 31 footer. I think the max weight is 7100lbs. I could go with two 4000lb axels and get 12 inch brake brackets on them? Which I believe is the 5 hole pattern?
Perry
Old 01-26-2012, 06:38 AM   #30
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Most 12 inch brakes I have seen are the 6 bolt pattern. All that i have had on Airstreams were.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-26-2012, 06:42 AM   #31
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Perry
Perry,
Your trailer has the typical 6 lug pattern. 4000 lb axle with 12" brakes isn't a problem either.
Colin
Colin H is offline   Reply With Quote
Old 01-26-2012, 06:46 AM   #32
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If we are talking about the mounting of the backing plate to the axle, the 12" is a 5 bolt pattern and the 10" is a 4 bolt pattern.
Richard
