01-25-2012, 02:05 PM
#21
Corona
Originally Posted by TG Twinkie
Axis acquired Henshen in 2010.
Axis dd not acquire Henschen.
Axis did purchase some of their equipment.
Axis also hired Henschens sales manager, who provided Axis with some information.
That person subsequently quit Axis as he felt that the big bosses "played too many games", which was his words, not mine.
As it appears today, there quite well may be different game plans, which depends on who the person may be.
01-25-2012, 02:37 PM
#22
1974 Argosy 20
Kooskia
, Idaho
I have Dexter's and had Luke (that is the only name he uses, just Luke) in Fort Collins CO put in for me. We talked about the options Dexter had and I went with the externally grease ones (a Zerk on the outside of the hub), self adjusting brakes, longer brake magnet wires (so the connections could be pushed above the belly pan) and as I recall a 4500 # rating for my single axle 20' Argosy. (I had it weighed and we went from there) I also had new AS shocks and Dexter factory built shock mounts.
One additional thing that can be set with Dexter is the length of the axle stub from the factory mounting brackets. My Argosy had it's tires running very close to the sheet metal outside, so I had my axle made one inch narrower, hub to hub face, so I had a small amount of additional clearance. That makes it easier to change tires.
Luke did a great job of installation, and guiding me through the possibilities of Dexter axles. This past summer I put 16" alloy wheels on and Goodrich LT 225/75 16" tires. The combination of all the small changes made for an excellent final result. Now, I just travel, with few worries, an occasional shot of grease in the bearings, and air pressure check of the tires. Life is good.
01-25-2012, 02:38 PM
#23
bilby05
1962 24' Tradewind
1962 24' Tradewind
Canyon
Which Axles?
I had Dexters installed and the results were good.
Just be sure you familiarize yourself with the specs that YOUR year and model of Airstream uses, be sure that your installer orders exactly according to those specs and understands the correct geometry of the mounting and shock absorber. I "thought" that mine did but when I went to pick it up everything was wrong. Fortunately, after a discussion with me and the nearest Airstream dealer, he realized his mistake and replaced the axles with the properly spec'd ones.
It's always about the details. Without everything being correct the advantage of new axles is greatly diminished.
cheers, bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
01-25-2012, 02:56 PM
#24
Moderator dude
1966 26' Overlander
Phoenix
GKN/Henschen closed in 2010. Assets were sold and that piece of business no longer exists.
>>>>>>>>>>Action
01-25-2012, 03:40 PM
#25
1977 27' Overlander
Trotwood
, Ohio
I purchased from INLAND and Andy arranged for my truck to pick them up at the factory(Henshen before they closed) and I installed them myself. I am very satified with the whole transaction.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
01-25-2012, 05:12 PM
#26
1981 31' Excella II
New Market
, Alabama
So Dexter makes the current axels for Airstream?
Perry
01-25-2012, 05:24 PM
#27
Retired.
, At Large
Perry
The two manufacturers of axles for Airstreams are currently Dexter and Al-Ko.
01-25-2012, 08:46 PM
#28
Corona
Perry
Your absolutely correct.
But, Dexter will not make axles with 12 inch brakes below a 3500 pound rating.
There are several thousands of Airstream trailers that are equipped with 12 inch brakes that are below the 3500 pound rating.
01-26-2012, 05:41 AM
#29
1981 31' Excella II
New Market
, Alabama
Well I have a 31 footer. I think the max weight is 7100lbs. I could go with two 4000lb axels and get 12 inch brake brackets on them? Which I believe is the 5 hole pattern?
Perry
01-26-2012, 06:38 AM
#30
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
Most 12 inch brakes I have seen are the 6 bolt pattern. All that i have had on Airstreams were.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
01-26-2012, 06:42 AM
#31
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru
, New York
Perry
Perry,
Your trailer has the typical 6 lug pattern. 4000 lb axle with 12" brakes isn't a problem either.
Colin
01-26-2012, 06:46 AM
#32
2002 25' Safari
Dewey
If we are talking about the mounting of the backing plate to the axle, the 12" is a 5 bolt pattern and the 10" is a 4 bolt pattern.
Richard
