Old 02-05-2006, 06:41 PM   #29
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by steelbird312
I ordered two #11 axles with a #3700lb rating so as to receive the 12 inch brakes/drums. I also ordered the 22.5 degree down on the start angle. The trailer sits up nice and pretty now. Pulls great. The main thing I am trying to tell you is that you can order anything you want in load ratings. I think you can even order #3600 in the #11 axle, still getting the 12" brakes.
I actually ordered the #10 axle, but with the #12 spindle, and a 3000lb load rating. This made the 12in drums possible. No mods were required to the cut-outs in the axle mounting plate.
I think that 3700lbs per axle on a 70's Overlander is too much. I had 3500lb axles shipped to me by accident by Henschen, and it made my TradeWind bounce like it had bad axles. Changing them to 3000lb axles made a huge, and I mean HUGE difference. The trailer rode like it was on clouds....
Uwe
www.area63productions.com
Old 02-05-2006, 07:14 PM   #30
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Uwe,
The trailer we put the 3700's on is 28' long, I'm almost positive it said Overlander on it. Anyway, I welded the shock mounts on, and we used C rated tires and it pulled like a dream. Course, we didn't try it off-road!
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 02-05-2006, 08:21 PM   #31
Originally Posted by uwe
Maybe we just had a run of bad luck, but I just can't agree to the statement that all axles are the same, and one might as well pick the cheapest ones. In my experience, this was a big mistake.
You obviously had much better results with Axis. Good for you!
I did not state that I picked the cheapest one. I had merely stated that I do educated research and pick what I want for the value.
Value=quality+price+ease of use. At least in my eyes.
I had wonderful satisfaction from ALL of the mentioned axle manufacturers.
PS Now that was good info that you provided. If you are going to site quality issues then you should state what was wrong for all of our benefit. Thanks and I am going to use your experiences to watch my axles.
Perception is reality and everyone perceives things in their own way. This is why I believe we have reached the level of understanding that we now share.
Anon is offline   Reply With Quote
Old 02-15-2006, 08:38 AM   #32
Somewhere , Indiana
Whaaaaaaaaaaaat's Up!
Originally Posted by davidh
The funny thing about my axles are I have the Henschen invoice but they came with a Dexter manual whats up with that I do not know.
F.Y.I.
Henschen does NOT manufacture the brakes or hubs - Dexter does and so do others. Henschen uses "others" components to build axles and has for quite some time. Dexter is the largest axle supplier in the United States.
Regards,
Henry
axleman is offline   Reply With Quote
Old 02-15-2006, 09:51 AM   #33
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
axleman Thats good to know, thats more than likely why I got a dexter manual, Henshen was using Dexter brake components on the axles that were purchased for my trailer.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-15-2006, 10:57 AM   #34
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Uwe,
It was likely an Ambassador. Overlanders for pre '69 were 26' and post '69 were 27'.
>>>>>>>>>>>>Action
Old 02-22-2006, 08:20 PM   #35
1968 20' Globetrotter
1955 26' Cruiser Overlander
Bastrop , Texas
Ok. This is all very helpful. Can anyone help me with if I should consider going from a single axle to a tandem. I understand about the wells and have someone who can work that out. It is a 59 Overlander and back then, only one axle. Will two axles help with a better tow or do I need to concentrate on quality of axle- single?
emo59 is offline   Reply With Quote
Old 02-22-2006, 08:33 PM   #36
Images: 59
We had this discussion a short while ago. Here is the thread for reference. http://www.airforums.com/forum...les-20770.html?
I know there will be additional comments.
Old 02-23-2006, 04:44 AM   #37
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Depends on total weoght towed including things that may be placed in it when towing.
>>>>>>>>>>>>>>Action
Old 03-19-2006, 08:57 PM   #38
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
31 Sovereign Axles
Originally Posted by stagecoachbill
I took my 62 Globe Trotter to Axis Products in Elkart IN . They took off the old axle and built a new one to match the old, and installed itl I drove away $442 later and have been very happy that I didn't have to do it myself.
I have a 73 31' Sov-I'd like to do the same thing. Did you replace the brakes as well? Did you pre-order? How long did the replacement take? Did you talk to a salesman?
trevisgardne is offline   Reply With Quote
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Price guide for site? ViewRVs General Motorhome Topics 7 01-04-2003 11:06 PM
Questions about the 2003 International. Would you buy again/fair price. Debbie 2002 - 2005 International 29 11-07-2002 04:11 PM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
