Old 01-29-2015, 11:44 AM   #1
GlamperGirl
Axle Panic - Need Advice - '65 Globetrotter
I ordered a new axle and it won't fit under frame properly without having to notch it out according to my installer. I ordered the correct axle according to the Vendor, but I got the "we sell it but we are not in the business of teaching shops how to install axles or other items for that matter" line when I contacted them about this issue.
Name:	ImageUploadedByAirstream Forums1422556988.576588.jpg
ID:	231338Click image for larger version
Name:	ImageUploadedByAirstream Forums1422556998.427442.jpg
Anyone with ideas on their axle install?
You can see the oblong hole in the axle bracket that doesn't have enough real estate to bolt through the trailer frame.
That is as high as it will go without not notching out the lower portion of the inside bottom of the frame.
thumbelinadj is offline   Reply With Quote
Old 01-29-2015, 01:43 PM   #2
Kevin245's Avatar
Hang in there. We have some very knowledgeable members here who should be able to advise you.
Eleanor Roosevelt
Old 01-29-2015, 02:01 PM   #3
GlamperGirl
You're a gem
Old 01-29-2015, 02:25 PM   #4
Central , Mississippi
Dont notch the frame!
Here is a solution since its already at the welders:
http://www.airforums.com/forums/f109...ml#post1441335
and a follow up
http://www.airforums.com/forums/f109...ml#post1451932
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-29-2015, 02:31 PM   #5
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
A reputable welder in your area can extend whatever is needed so that it will work safely. From the pic it looks like the track width is correct, and that the mounting flange abbuts the inside frame chanel. If that wasn't the case I would have the vendor re-double check the fitment. Should take about 5-6 hours to do both sides from what I see.
Hope it is easier than you expected. Nice GT too.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 01-29-2015, 03:02 PM   #6
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I had a similar prob w/ my 65 overlander . I was told by the vendor to notch the mounting flange on frame, in my case about 3/4" upwards to bottom of frame. This made sense b/ c original axle didn't rest on bottom of frame, rather the weight of trailer was supported by the axle bolts!
So , I notched the frame plates& axle went in,BUT.... The trailer say lower than before the axles swap! This was a major PITA to remedy. I had to make extension plates & hire a welder, etc. Apperently, 65s were a transition year. Nothing like having to do the job twice! Click image for larger version
Name:	ImageUploadedByAirstream Forums1422568950.739001.jpg
Cochese is offline   Reply With Quote
Old 01-29-2015, 06:35 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Not to panic. Be cool, calm, relaxed. We have all had modifications to do to the frame and or axle brackets to get the new ones to fit up. I used Axis axles on my 66 Trade Wind. I had to deepen the notch and drill new holes. At least no welding. But welding is a basic process that a lot of folks can do. I think it is important that the axle bracket rests on the frame rail. The bolts just keep the axle tight to the frame in case your Airstream starts to fly or something. And it's important the shock mount bracket and bolt allow shock assembly and removal with the axle bolted up.
Here is what I had to do on my Trade Wind. I made a template and started grinding away. You can see sparks in my photo! Nose to the grindstone. My trailer also got about 3/4" lower, but the new axle recovered most of this ride height loss. I used 22 degree starting angle like the original. I think I would have prefered something a little higher had i known I needed this modification. But I knew I didn't want 32 degrees. That's too high for me. I didn't want to use a step ladder to get into my Trade Wind!
David
Name:	1406 Axle Template.jpg
ID:	231361   Click image for larger version
Name:	1406 Axles Both Mounted.jpg
Old 01-29-2015, 06:59 PM   #8
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I also used a 22.5 axis axle, but the trailer was almost an inch & half lower! A 26' A /S can become a real tail dragger if it sits too low! Now I almost forgotten about having to do the axle job twice ! Just remember , restoring an Airstream is a hobby!
Old 01-29-2015, 07:01 PM   #9
GlamperGirl
It's a hobby. It's a hobby. It's a hobby. Ok. I think I have three good ideas. Will be at the shop checking it out tomorrow. Too bad I didn't know better. But not I can write a lesson up for someone else. I had the welder her all last week and could have done that work less expensively. Love you airstream Angels. Dena
Old 01-31-2015, 06:32 PM   #10
GlamperGirl
Axle is great. Work was superb by my GREAT technician. Still irritated the vendor told me in email to go find someone else because she thought from one five minute phone call the company was not going to work. I'm getting lots of private messages on the poor service from the axle provider. With that said this thread is done. Thanks all for the awesome support.
Old 01-31-2015, 07:05 PM   #11
Kevin245's Avatar
Glad to hear that things ended well DJ.
Eleanor Roosevelt
Old 02-01-2015, 07:39 AM   #12
Regular Guy
1978 31' Sovereign
Awesome. So what was the fix? I have to replace my 2 axles, who is this vendor that I should avoid? PM if you care to.
Clayton
Old 02-01-2015, 11:42 AM   #13
GlamperGirl
The fix was several things. Not to mention correct bolts. Removing a welded part on the frame that blocked the motion of the shock. Adding a plate to bolt it on. I'll get photos after I recover from watching the Seahawks win the Super Bowl today
Old 02-01-2015, 11:52 AM   #14
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Glad to hear it all worked out. I remember replacing my axle was a pretty stressful time (and I had a shop do it), but the good news is that for the last ten years I haven't had to think about it at all Check that one off your list and move on!
Stephanie
Panic is setting in.... arktos55343 Repairing/Replacing Floor &/or Frame 255 07-20-2017 12:01 AM
Can't find covered storage in Denver ~ Starting to panic Travel Bird Winterizing, Storage, Carports & Covers 21 10-10-2012 05:15 PM
1985 Excella/Sovereign PANIC! wpmartin 1984 -1986 Excella 16 04-02-2006 06:42 PM
Panic! Can we polish this?????? a-wanabbee Cleaning, Stripping & Polishing 7 03-20-2006 02:08 PM
