Old 07-03-2005, 12:25 PM   #1
jgouras's Avatar
1966 24' Tradewind
snohomish , Washington
axle nut torque value??
need to put my wheels on. how tight to make these castle nuts? please help.
jgouras is offline   Reply With Quote
Old 07-03-2005, 04:31 PM   #2
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Look here ...
jgouras
Try buttercup's web site ...
http://overlander.archnevada.com/index.php?home
specifically:
http://overlander.archnevada.com/ind...d=18,0,0,1,0,0
There are others within this Forum ... use 'Search' tool at top.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 07-03-2005, 04:41 PM   #3
jimmickle's Avatar
2000 31' Land Yacht
Tighten to 15 lb. ft. while turning hub. Loosen. Tighten to 15 lb. inch (finger tight). Back off 1/2 to 1 flat and install cotter pin.
Jim Mickle
jimmickle is offline   Reply With Quote
Lug Nut Torque? carver 1 Wheels, Hubs & Bearings 7 01-04-2014 06:48 PM
Lug Nut Torque Value? nm1oqrz Wheels, Hubs & Bearings 1 05-14-2011 02:18 PM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Lug Nut Torque alan Wheels, Hubs & Bearings 46 11-27-2006 09:32 PM
Wheel nut torque on aluminum wheels Tom Nugler Mechanics Corner - Engines, Transmission & More... 3 09-04-2003 07:03 PM
