Old 05-21-2012, 02:48 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Axle mounting bolts-best lube to free up?
I,m going to do axles. What do you use to prep the bolts/nuts?
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 05-21-2012, 03:08 PM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I used "Blaster" when I did my axle. I sprayed the bolts a couple of times over 3 days. It was still a tough job. A torch would have been much faster for me.
PB Penetrating Catalyst
The world famous PB Blaster Penetrating Catalyst is more than just great. PB quickly breaks loose surface tension rust and corrosion by creeping up, around and in to hard-to-reach cavities. It's ideal for brake, exhaust and suspension system jobs. Plus, lubricating film remains on parts to help prevent further rusting.
  • A true penetrant
  • Formulated in 1957
  • Rust inhibitor
  • Breaks loose surface tension of rust/frozen parts
  • Much higher flashpoint ** 152F
  • Non-evaporating lubricant
  • Saves time & money by ensuring user will not have to burn off or drill out nuts & bolts or other expensive & time consuming means of repairs
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 05-21-2012, 03:15 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Kroil is the best stuff I have found. An old aircraft mechanic told me about it. He used it to free waste gates on turbo chargers, good stuff. PB is good too.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-21-2012, 03:25 PM   #4
2005 19' Safari
GLENDALE , AZ
I suspect shops use an impact wrench. If you don't have an air gun, a couple of whacks with a hammer would probably loosen up the rust. And, if nothing else, it might let a little more penetrating oil into the threads to soak overnight.
Old 05-21-2012, 04:00 PM   #5
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
A torch is the best! Kroil is next best. Also a homemade penetrant that works well is ATF & acetone mixed 50/50.
Diesel1 is offline   Reply With Quote
Old 05-21-2012, 06:10 PM   #6
Max Well's Avatar
1971 25' Caravanner
Olathe , Kansas
+1 on Kroil! Been a professional mechanic for 35 years, best stuff I ever used!
"Surrender is not in our creed. Let me hear you say that..." Gunny Hiway
Max Well is offline   Reply With Quote
Old 05-21-2012, 06:17 PM   #7
Thanks for all the responses. This forum is the greatest!
Roger
Air# 29488
Old 05-21-2012, 06:36 PM   #8
Where do you get Kroil? Napa auto parts? Pep boys?
Roger
Air# 29488
Old 05-21-2012, 07:06 PM   #9
68 TWind's Avatar
1968 24' Tradewind
My local NAPA has it, but yours doesn't they can most likely get it the next day on the delivery truck. If they can't get it there find out if there is a aircraft supply house close by. They will have it. I never known an A&P mechanic without a can in their tool box.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-21-2012, 07:16 PM   #10
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
And if some PB or Kroil and an impact don't get the job done ... you may be in a place where use of a torch is an issue, due to position of coach floor, brake wiring, clearances, etc. --- in such circumstances, I often find that a nut splitter is just the ticket. Easy to use, and once the nut is split, it'll come right off. I carry two sizes in my portable tool box. Indispensable.
Ever notice how the nuts you just have to get off are the ones that never had anti-sieze put on them earlier? Why is that?
AirsDream is offline   Reply With Quote
Old 05-21-2012, 07:21 PM   #11
richinny's Avatar
2011 34' Classic
if you can get at the nuts with a wire brush and clean any exposed threads it will help the solvent get in and make backing the nuts off easier.
Ricky
Old 05-22-2012, 06:09 AM   #12
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
PB Blaster worked well for me when I replaced my axles.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 05-22-2012, 08:02 AM   #13
Luckyducks's Avatar
2018 27' Flying Cloud
Panama City Beach , Florida
Another vote for Kroil. The boatyard I use buys this product exclusively to free up marine rusted parts.
Russ and Linda
2018 Flying Cloud 27'
2012 F250 Powerstroke 6.7
AIR#24440 WBCCI#11740
Luckyducks is offline   Reply With Quote
Old 05-22-2012, 08:09 AM   #14
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I used blaster and soaked them down many times for about a week. They came loose with a 2 foot breaker bar. Also found an impact wrench at tractor supply for $20.
Silverflames is offline   Reply With Quote
