Old 05-22-2012, 02:28 PM   #15
East Tawas , Michigan
I have used a lot of PB on my bolts over the course of several weeks,still won't budge. Today I tried the shock stud and it snaped off.Now what do I do ? Don't mean to hijack the thread, but thought it might help others in the same spot.
baylito99 is offline   Reply With Quote
Old 05-22-2012, 03:00 PM   #16
Ahem, yasss ...kaff-kaff
egad's Avatar
1969 27' Overlander
Bloomington , Indiana
Originally Posted by rogerdodger View Post
I,m going to do axles. What do you use to prep the bolts/nuts?
If you don't have an acetylene torch to do cutting, a propane torch can work wonders. Just heat the nut for a minute or so and let it cool. The expansion from the heat is often enough to break the rust bond.
egad is offline   Reply With Quote
Old 05-22-2012, 05:21 PM   #17
Baltimore , Maryland
Okay, really going to throw this one for a spin...
a sawzall with a torch blade works faster than PB blaster/ kroil and an impact driver. We don't bother even trying to get them loose. We just cut between the head and the mounting plate. 15 seconds per bolt. Just my personal experience from changing dozens and dozens of axles.
Old 05-22-2012, 05:28 PM   #18
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Roger
Kroil can only be ordered direct from the company. Either by phone 615-833-410 or from thier website WWW.KANOLABS.Com
Kroil is not sold in stores.
I have 1 8 oz liquid and 1 80z spray can that I ordered direct. It works great on my antique tractors and anything else I have used it on. Caution its expensive but worth every penny.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 05-22-2012, 08:38 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If there is an AGCO tractor dealership near you. Their brand of penetrating oil is the best I've come across.
I recently installed new axles on my 38 year old Argosy. I used this penetrating oil and had no problems getting the nuts off of the axle mountings or the shock mountings.
There is also the method of splitting the nut with a sharp cold chisel. If you try this on the shock mount bolts don't bang on the chisel hard enough to bend the stud. The chisel should be kept sharp.
Old 05-22-2012, 09:34 PM   #20
rogerdodger's Avatar
Fresno/Clovis , California
Ok guys, all great info. Thanks, as always this forum is the greatest.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 05-23-2012, 07:53 AM   #21
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Inland and other places sells the replacement shock stud, the old one will have to be cut out, and the new one welded back in. Heating the nut with a torch works well many times, pull the other shock studs loose first, then you will know how many to order. The axles come with mounting hardware.
Silverflames is offline   Reply With Quote
Old 06-01-2012, 09:47 AM   #22
howco's Avatar
1970 27' Overlander
Sumner , Washington
Kroil, the best. It is available online or at most small airports.......
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
