Old 09-22-2013, 10:55 AM   #1
retrocar66's Avatar
1967 24' Tradewind
Greenville , North Carolina
axle mounting bolt torque
Is there a proper torque for axle mounting bolts? If I mount my new axles with a 1/2" air wrench that can go to about 400-450ft lbs, is that enough?
Also, I'm not sure the new axles will come with mounting hardware. Is grade 5 sufficient for this application, or do I need grade 8.
retrocar66 is offline   Reply With Quote
Old 09-22-2013, 11:00 AM   #2
Grade 5 is OK, but grade 8 is far superior.
We have supplied the grade 8, for many years.
Old 09-22-2013, 12:54 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There are tables on the Internet showing the torque specs for each grade of bolts. 450 ft pounds is way too much for a 5/8" bolt. Grade 8 bolts are recommended.
Old 09-22-2013, 02:26 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Here's a chart on this page for torque specs for axle mounting, from Dexter.
Suspension Maintenance for Trailers
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 09-22-2013, 02:47 PM   #5
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Definitely go grade 8
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 09-23-2013, 03:22 PM   #6
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Grade 8....Clean the mating surfaces. If you use lock washers use highest quality. Finish tighten with a breaker bar if you don't torque. Above all else check them at least once after a few miles.
putback is offline   Reply With Quote
