Old 01-29-2013, 07:25 AM   #1
SomthngShiny's Avatar
1976 31' Excella 500
Walker , Michigan
Axle Measurements
Hi All,
Long time Wannabe, First time Owner....
Does anyone have the necessary measurements to replace (order) the axles on my '76 Excella 31'? I would like to increase the ride height at the same time. My tow vehical is a F-350 Supercab with a V-10.
SomthngShiny is offline   Reply With Quote
Old 01-29-2013, 07:47 AM   #2
1982 34' Limited
Harrowsmith , Ontario
Hi Bob,
What company are you going with? I went with Axis through Colin Hyde and did not need to provide him any measurements - drop in replacement though. I've got the same trailer just not the Excella. I'll hopefully have them in a few weeks. I checked Dexter too but there were very expensive here and they would not have been drop in.
BradB is offline   Reply With Quote
Old 01-29-2013, 07:49 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Call Dexter and have them send you the applications manual. the dimensions you will need are:
fish plate to fish plate mounting flange inside and outside
hub face to hub face
axle rating
trailing arm angle (22 1/2 degrees is the original)
hub bolt pattern
Lumatic is online now   Reply With Quote
Old 01-29-2013, 09:03 AM   #4
1976 31' Sovereign
Oswego , Illinois
I pur. axles yesterday [1/28/13/ from Colin Hyde for 1976 31 Ft. AS, Axis axles has correct specs for AS. Colin is very nowleadgable very pleasant to deal with no need to measure, Just tell him what you want.
featherbedder is online now   Reply With Quote
Old 01-29-2013, 09:36 AM   #5
Originally Posted by SomthngShiny View Post
Hi All,
Axle specs are not needed when purchased from a well known supplier.
Changing the originals spec, is a different matter for someone that is not familiar with the "how to".
Altering axle specs for owners replacement axles to accompodate different tasks from the original axles, is done everyday.
Old 01-29-2013, 09:59 AM   #6
JackP's Avatar
1972 27' Overlander
New Haven , Connecticut
I agree with the others - order through Colin Hyde. I just told him which trailer I had and he knew which axles to order.
JackP is offline   Reply With Quote
Old 01-29-2013, 10:54 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It is a good idea to take the measurements, however. It was an improvement with my '75 Argosy to go with the "standard" hub face-to-hub face measurement (the wheels are better-centered in the wells now, they were closer to the frame than the skin before) it would have been useful to know that the aft flange-to-flange measurement is different from the forward one that I measured (and that is close to the spec.) The rear axle required a spacer plate because of that off-square condition, but they work great.
I'm sure that 99 time out of 100, the standard measurements fit up perfectly. I ended up with one of the "unique" ones.
— David
Old 01-29-2013, 11:02 AM   #8
Walker , Michigan
Thanks Everyone
I am hoping to source them myself......Budget wise.....I know, it's an "Airstream", but I live reasonably close to the manufacturers. I have contacted Colin, and I am waiting for a quote from Andy @ Inland RV.
Long Time Wannabe, First Time Owner
Old 01-29-2013, 04:52 PM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Before you order, make sure of the return and warranty policy of whomever you order from. Ask them if the axles are not what was ordered, or if there were errors in manufacturing, what their policy for taking care of the problem is. I know of several axles that were either not what was ordered, or the incorrect axles were built, and the long time dealer refused to make good on it. Those people now have spare axles that won't fit anything.
Old 01-29-2013, 05:32 PM   #10
Baltimore , Maryland
There are very few differences in the measurements, however I have found that not all are the same. A very common measurement is 58" bracket to bracket and 75" hub face to hub face. I have seen that 58" vary a great deal however. I seen it 57 7/8" and have seen it 58 1/8". I always measure even though my axle guy has more years doing this than I have been alive. The last thing I want to do is shim or cut. I want to put them in.
Old 01-29-2013, 05:34 PM   #11
That is a great desire but unfortunately none of the manufacturers are going to deal with you directly. I, as a guy who installs axles all the time have to deal with a middleman too.
And a real important point; DO NOT let someone talk you into 10" brakes. You are not saving anything worth saving by doing that. Brake technology might have improved, but more stopping is more stopping and going with 10" brakes only makes the bottom line look better on paper.
Old 01-29-2013, 05:34 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you are considering using a local manufacturer. I would suggest removing one of the axles and taking it to them. Your trailer tag should show the axle rating, plus there should be a tag on the axle with the data. One should consider increasing the axle rating slightly when installing new axles.
Old 01-29-2013, 05:52 PM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
When I got my new Dexters the brackets were a little off. I called Dexter and they said their tolerance was + or- 1/8". Shimming is no big deal it would be a problem if they did not fit because they are too big.
Also if you order to spec make sure you emphasize high profile reverse orientation mounting brackets or they won't fit.
You can also ask for a shock mounting bolt to be installed.
If all this makes you too nervous go with Colin Hyde or Inland who knows what you nned.
PS
I have 10" brakes on my 4500 pound Tradewind and have absolutely no complaints. This was also the difference between ordering a #10 and #11 axles and considerably cheaper.
Old 01-29-2013, 05:52 PM   #14
JackP's Avatar
1972 27' Overlander
Just realized that Andy from Inland sell axles too. Although I didn't buy my axles from him I did purchase an awning and a few other items from him and was very pleased.
