Old 09-18-2012, 05:56 PM   #29
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Oh and if you go with the Dexter # 11 your minimum weight rating is 3800#, not a bad thing with the triple axle setup.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 09-18-2012, 06:07 PM   #30
Originally Posted by Steve Bryant View Post
So, does anyone know what my hub to hub measurement would be if my mounting brackets measure 61.375" on a 1991? Note: I'll verify all of these measurements again when I have the wheels pulled and before I order the axles.
Steve
Steve.
I would suggest that you increase the axle rating to 4000 pounds, as that's what they are on later 34's.
The hub face to hub face is 80.75"
You can also now get them with self adjusting electric brakes, or if you wish, you could upgrade to disc brakes.
The basic difference is the cost of the actuator.
Old 09-18-2012, 10:25 PM   #31
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Greg and Andy,
Thank you both very much!!!
Steve
Steve Bryant is offline   Reply With Quote
Old 09-20-2012, 06:26 AM   #32
1976 31' Sovereign
Springfield , South Carolina
OK I have a L S Starrett 12" Vernier Caliper inbound. If I am lucky it will be here Saturday via Priority Mail.
I have a form made out I will publish on my gmail account with a link for all to reference and a blank form others are welcome to use when measuring their units to order axles.
I will measure all four hole locations C-C, I-I and O-O and figure a average.( I already know the hole sizes are different on the first set of holes).
I will also measure all hole sizes so we will have a range of hole sizes known for reference purposes at least for a 76 Sovereign 31'.
The place I am getting mine from will custom drill holes on locations you spec.
Hummer is offline   Reply With Quote
Old 09-20-2012, 05:48 PM   #33
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You don't need calipers to measure the distance CC on the holes. If the holes are round and the same size, just measure from edge to edge. Measure from the left edge of one hole to the left edge of the other hole for example.
Old 09-21-2012, 08:31 AM   #34
1976 31' Sovereign
My holes vary in size by like .035" ! ! ! ! if I remember correctly. As well the inside of the holes being stamped are shall we say chamfered. Personally I would prefer a rather precise reading as I have machine operations background and own my own lathe and mill and a caliper to me is the way to go as I know it will give much more precise measurement for the actual hole locations C-C.
Assuming the hole locations are identical on all the 31 Sovereigns then those of us that have them will know what to order for a more precise fit.
My data that I publish will need to be confirmed by several others of course.
Old 09-25-2012, 01:19 PM   #35
1976 31' Sovereign
I haven't forgotten the measurements. It is just this Gout has got me crippled now but getting better slowly. I cannot wear left shoe at all.
I did get in my Starrett Vernier and though it is old it is as if hardly ever used and checks out good. Soon as I can walk half way I will measure the sets of mounting holes.
Old 03-11-2013, 04:57 PM   #36
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
So much for the database.
1996 Excella 28' GVWR: 8200 (as it sits: 7100 on the axles)
This is my order:
Axle: #11 Torflex
Quantity: 2
Capacity: 4,500 lbs. (originals were Dexter 4,000lb axles)
Hub Face: 86.0"
Bracket outside: 67.0"
Bracket orientation: Reverse
Bracket profile: High mount
Start Angle: 32 deg down.
Lubrication: Nev-R-Lube
Bolt Pattern: 6 on 5.5" (655)
Stud size: 1/2" - 20
Brakes: 12" electric, auto adjusting
Custom: Torsion Arm welded shock mount
Notes:
"Before" Ride height: 25" Ground to Center of wheel arch.
Tires: 225/75-15 Goodyear Marathon Radial ST load range D
Wheels: 2013 Aluminum OEM max 2850lbs. ea. (I didn't write this down, but I remember it was 2,8xx lbs.)
$599 each from my local trailer parts retailer.
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Old 03-12-2013, 05:31 AM   #37
1976 31' Sovereign
This is axle data plate as installed on 76 Sovereign
Old 03-12-2013, 05:50 AM   #38
1976 31' Sovereign
This is template I fabricated that aligned the AS frame holes with the axle shaft so I knew exactly where to relieve the mounting plate to install the axle.
Old 03-12-2013, 10:01 AM   #39
Greg@AirLA's Avatar
1960 24' Tradewind
Kevin:
You're so close on the dimensions that I don't think it'd make a difference, but the factory specs are 86.43" hub face and 67.125" outside bracket dimension.
Greg
Greg Paulsen
Old 03-12-2013, 10:18 AM   #40
1996 28' Excella
Portland , Oregon
Originally Posted by Greg@AirLA View Post
Kevin:
Greg
Thanks Greg. I got a PM that 2 of my measurements were off, but no indication of which two. It really did scare me because if it's done wrong, it's on me. Well, the Six Robblees Distributor has a 50% restocking fee. Which I think is generous knowing that if it's done wrong, it's pretty much scrap metal.
It's also pretty difficult to make the measurements by yourself with them on the trailer. I would take one off to measure it, but I have to cut one of the bolts to get it off. The spindle arm doesn't move out of the way.
You're right, the Hub face probably won't make a difference, and 1/16th on each side of the mounting plate won't be a deal killer. I'm just surprised that I was off by that much.
I haven't made the order yet, but I will this week. I might do my measurement with a neighbor since the wife is not really excited about being my helper.
-Kevin
Old 03-27-2013, 07:40 AM   #41
1976 31' Sovereign
Here is what the old (1976)factory 3200 lb axles looked like after having weight off them for three weeks up on jack stands and the new 5200 lb axle just installed.
This is bracket I made. One set of holes locates 8 Lug Hub face and the other a 6 Lug (Airstream) Hub face.
This shows how bracket is attached to hubs to measure the hub face on one side.
And this is the other side. This way you get a dead match for the axle you are removing and you can look at how your wheels locate in the wells and you can change this dimension. On mine the left side mounted closer in than right side so I increased the hub face dimension a tad to center the wheel a little better in the well.
Old 03-27-2013, 08:25 AM   #42
Henschen always said, never increase the rating more than 15 percent, or there abouts.
Your's have increased over 60 percent.
Unless your Airstream is very heavily loaded, which the chassis cannot handle, watch for sheared rivets, and fatigue crack damages, to the shell and chassis.
Those are the warnings issued by Henschen many years ago.
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
