Old 05-21-2007, 05:54 PM   #1
martinez , California
Axle life
Hi all,
Just bought a 1979 Argosy Minuet. Towed her down to SF Bay area from Oregon with my fingers crossed. Now I'm trying to make her safe, after safe we'll work on pretty. The old girl is 28 now. My question is what is the service life of a Dura torque axle. What are the signs it's time for a new axle. If it's time for a new axle what axle is most favored?
PS This trailer is going to see alot of time on dirt and gravel roads in Idaho and Montana.
Uncle Jack
Uncle Jack is offline   Reply With Quote
Old 05-21-2007, 06:29 PM   #2
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Jack,
The design life of a rubber torsion axle is about 20 years. That said, many make it to 30, but few make it past that. The axle arm should be horizontal with the trailer frame or even have a slight down angle if it's still good. If it's pointing up toward the floor, the odds are it's bad.
A quick check is that you ought to be able to see most of the tire sidewall in your wheel well. The less you can see, the less competent your axle is.
Good luck!
Roger
85MH325 is offline   Reply With Quote
Old 05-21-2007, 07:15 PM   #3
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1977 25' Tradewind
Eastern , Washington
So Sorry but it's probably gone.
Originally Posted by Uncle Jack
Hi all,
Uncle Jack
The Axle was one of the first things replaced on our 1977 Minuet. Nothing lasts forever. We replaced our axle with a 33 deg. down angle and it gave us a lot of ground clearance for those dirt roads. Take a look at Airstream Innovations at Inland RV Center, Inc. (951) 734-8130 axle tutorial. It will give you a graphic example of what you're looking for.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 05-22-2007, 05:16 PM   #4
Originally Posted by 85MH325
Jack,
Good luck!
Roger
Many 40 year old Airstreams, still have good axles, in spite of the fact that there are many failures because of the composition of the rubber from 1974 and older.
From 1975 and newer, the rules are the same. Use the axles. Non use will guarantee bad axles in as little as 3 years.
Storing the trailer long term is OK, but, removing most of the weight from the axles, is the key.
Rubbers memory can be destroyed. Rubber must also be exercised, to keep it alive.
Andy Rogozinski
Inland RV Center
Corona, CA
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 9 04-21-2020 10:57 AM
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
