Old 05-10-2004, 12:54 PM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Axle in Connecticut
Andy here's the pictures. I'll call
ID:	6511   Click image for larger version
Over59 is offline   Reply With Quote
Old 05-10-2004, 09:11 PM   #2
Over59's Avatar
Images: 37
That bracket seems mounted backwards. The stud would clear if it was flipped around.
Old 05-11-2004, 08:42 AM   #3
Paul.
The shock brackets sometimes must be bent to obtain clearance.
If the bracket was turned around, the shock would hit the tire.
The shock bracket location, is dictated by the location of the torsion arm.
Bambi's and Caravels provide a real challenge with the newer style larger torsion arms.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-11-2004, 02:54 PM   #4
fbaileysr's Avatar
Changed shocks on my 1988 Excella and had the same problem. What I did was take the rubber out of the mounting hole and put that on first with plenty of oil. This gave me a little more wiggle room, then worked the shock on. It still takes some moving around but it worked for me.
fbaileysr is offline   Reply With Quote
Old 05-11-2004, 04:48 PM   #5
Over59's Avatar
Images: 37
Trailer place called and sid camper is done. I'll pick up Friday and get to see how they did.
