Old 04-20-2013, 03:31 PM   #1
shadeemry's Avatar
1975 31' Sovereign
cary , North Carolina
Axle identification
Ok, so I just jacked up my airstream to change the backing plates and made a rather disturbing discovery.. I don't know what's goin on , and why the rear axel looks different then the front axel, or why one is higher then the other. I have included pictures and was wondering If anyone can identify the axels. The reason I'm asking is because I went and got another frame to use the metal off of it and the axels were included. It's the same year and model frame, but the axels look different. These have bolts that screw in the hubs, and the ones on the airstream has posts...
ID:	183856   Click image for larger version
shadeemry is offline   Reply With Quote
Old 04-20-2013, 03:33 PM   #2
shadeemry's Avatar
1975 31' Sovereign
And these are the ones on the donor frame.
ID:	183859   Click image for larger version
Old 04-20-2013, 04:34 PM   #3
larry b's Avatar
1975 31' Sovereign
howell , Michigan
The hubs/drums on your donor frame looks like they are original. The hubs/drum on your trailer have probably been replaced. My guess on why one is higher than the other, it may be because the one is frozen/stuck and doesnt have any movent to lower when the weight is removed from the axle.
larry b is offline   Reply With Quote
Old 04-20-2013, 04:36 PM   #4
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Based on the pictures it looks like your jack stands are under the axle. When supporting your trailer with jack stands you should place the stands under the axle plates not the axles.
Old 04-20-2013, 05:23 PM   #5
It appears from your photo's that all 4 axles rubber rods are history.
The following will help you check out the axles, correctly.
The Dura-Torque Axle
Old 04-20-2013, 07:09 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Be safe
The frame that is supported by the concrete masonry units (CMU) is EXTREMELY dangerous. The CMU are set in their weak plane and are in danger of collapse under the weight of the trailer. (the holes in the CMU should be vertical like they would be in a wall to get the most structural support) As they are now the slightest vibration might cause the CMU to crack and let the trailer fall. Please do not let anyone under that trailer until it is supported.
I recommend that you do not use CMU for this purpose.
Alan
Old 04-20-2013, 08:31 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The good news is...
Well, first the good news:
The axles look like they are all originals, all four of them. That is good because you won't feel so bad having to buy new axles from improperly jacking and supporting them, and replacement axles generally come with new drums and backing plates.
Now, the bad news is, even if the axles weren't bad to begin with, they almost certainly are ruined by jacking and supporting the trailers on the hollow axle tubes.
Old 04-20-2013, 08:55 PM   #8
1977 Argosy 24
Milltown , Wisconsin
If you are EVER going to support something heavy with a cement block, set them the way they would be in a building. Then put a piece of 2X8 on top of the cement block, to spread the weight out over the top of the block. If you do not use the wood on the top to spread out the load, you risk splitting or crushing the block.
ventport is offline   Reply With Quote
Old 04-20-2013, 11:11 PM   #9
shadeemry's Avatar
1975 31' Sovereign
thats the donnor frame
Old 04-20-2013, 11:13 PM   #10
shadeemry's Avatar
1975 31' Sovereign
its a good thing im getting new axels then.. what are some good ones to get?
Old 04-20-2013, 11:24 PM   #11
shadeemry's Avatar
1975 31' Sovereign
Thankx a bunch andy
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
