Old 05-05-2007, 11:16 AM   #1
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
axle for 63 tradewind
I have torsion bar on my axle is this better or worse then leaf springs? also how do i know if axle springs are bad? also if i replace the shocks will that help the axle? I just purchased this a week ago totally gutting it should be done in a month will put pictures on here before and after also i thought you were talking about total weight of trailer from factory manufacturer says its 3500# with 415# tongue weight but how do i check numbers on axle?
1963tradewin is offline   Reply With Quote
Old 05-07-2007, 07:43 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Torsion and leaf are different from each other. Both have good and nopt so good aspects.
>>>>>>>>>>>>>>Action
Old 05-07-2007, 10:04 AM   #3
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Torsion Axle
If what you have is good, great.
If you use the "search" option and type in "torsion axle" you will find a huge list of threads. There are different schools of thought and it is worth taking the time to learn them.
Why not wait a bit on the axle to figure out just how much weight your rig will carry when you finish your restoration/customization?
You might find that the axle you need is different than what you think.
R
fastrob is offline   Reply With Quote
Old 07-20-2007, 10:13 AM   #4
1963 24' Tradewind
, , Minnesota
yaaaa hooooo I just bought a brand new Dexter Axle for 511.25 Brand new complete with brakes and bearings with a 6000lb cap What A Deal minneapolis wanted 692.25 for a 5200lb cap so I went to the country and bought one from a small axle place hopefully this will help others who are looking and do do do research to get a killer deal GOOD LUCK TO EVERYONE WHO NEEDS ONE im going to be singing on the road again by willie until next time take care of yourself whoever you are
Old 07-24-2007, 05:28 PM   #5
Somewhere , Indiana
You will be happy with your purchase down the road as well - Dexter has over 300 service centers accross the U.S.A.
You're in good hands!
Cheers,
Henry
axleman is offline   Reply With Quote
Old 07-25-2007, 01:08 PM   #6
Unless you heavily load your Airstream, the 6000 pound axle will certainly take a negative toll on the trailer shell and it's components.
6000 pounds is 1000 pounds over the Airstream engineered requirements.
Old 07-31-2007, 10:22 AM   #7
1963 24' Tradewind
, , Minnesota
Rivet axle
Good call andy, since it takes 2 weeks for a custom order im safe I called my guy and he said it will not be a problem to change it to a 5200lbs they will just have to shave the rubber deal running thru the axle sounded kinda funny to me so i asked he said this is how you get a 5200 one when buying new will have to pick up myself in st cloud so i dont have to pay frieght will be ready in about a week and my guy says it will be cheaper then the 6000 lbs one too thanks again for the advice
Old 07-31-2007, 10:34 AM   #8
1963 24' Tradewind
, , Minnesota
these are the rims and tires i'll be using, I got 10 ply instead of 8 because i read that you want tough tires on single axle tradewind
Old 07-31-2007, 11:21 AM   #9
Images: 59
Good move on the axle. Those tires won't take you much above 5200#. I had 12 plys on my Tradewind, they rode pretty hard.
Do you have a skid bar or other means to keep the wheel off the pavement if the tire goes flat?
Old 07-31-2007, 07:24 PM   #10
1963 24' Tradewind
, , Minnesota
No skid bar. Was this an option in 63? Do I need one? On the tires Im hoping mine dont ride hard just wanted a little extra security.
Old 07-31-2007, 08:23 PM   #11
Images: 59
I don't know for sure. I put solid plates under the spring mounting plates on my '59 Tradewind, but that was a leaf spring axle. The skid plate protects the U-bolts that hold the axle on.
On a single axle torsion axle I don't know what the recommendation is. What would happen if you had a blowout? Would the entire underside of the trailer be ripped up, or would the wheel and hub keep everything out of the asphault.
As you can see in the picture, if I have a flat the first thing to touch down would be the bottom spring mounting plate.
Old 07-31-2007, 09:27 PM   #12
1963 24' Tradewind
, , Minnesota
On mine the axle bolts are above the axle so if i had a blowout it would ride on the rim nothing sits low on mine. If the whole tire came off it would have enough clearance riding on the drum still. I'll take pictures tomarrow and show she dont look too good under there now tho and I think someone lost a tire from a bearing going out on the left side because the drum has been dragged by the looks of things and my left wheel well needs repair and when we did the floor a new rib was welded in there. The hub on that side also has 9/16 stud and passenger side has 1/2 stud. My new axle on the way has 9/16 studs. The good thing is the frame still looked real solid and had black paint on it thru out with minor surface rust when removing the floor and judging by the floor I dont think anyone ever replaced it. I don't plan on fixing the aluminum sheet over the wheel well until next spring tho too much work for this year. I definately am going over the budget on this thing but I think it will be well worth it when im done.
Old 08-03-2007, 03:48 PM   #13
Skid plates
Skid plates, were popular in the early 60's.
They should be "not" be attached to a torsion axle.
The u-bolts when properly tightened, could damage the axle tube, therefore changing the axle behavior.
Old 08-17-2007, 01:42 PM   #14
1963 24' Tradewind
, , Minnesota
Axle pic
Here is the picture of my underside. Thank God I purchased a new one before she went out.
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
