Old 11-13-2011, 06:55 PM   #1
1969 18' Caravel
portland , Oregon
Axle dolly made replacement pretty easy.
I changed my axle by myself today & was pretty concerned about getting the new axle under the trailer before jacking it into place. I had a 2x12 lying around and attached some casters to it. I used this to remove the old axle and then to put the new axle into place. Other than having to go from one side to the other on the trailer more than I would have liked, this really made the job pretty easy. Maybe there are hundreds of other posts using this technique, but it sure made this job easier than I expected.
I think I'm getting close. Maybe, after 2 years of work, I'll be ready to take the trailer on the road this spring.
Scott
ID:	145156   Click image for larger version
Name:	old axle on cart.jpg
Name:	new axle on cart.jpg
ID:	145158   Click image for larger version
Name:	Airstream 11_12 (3).jpg
scottwtalley is offline   Reply With Quote
Old 11-13-2011, 07:05 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Beautiful work on that interior! I used a dolly as well;. I clamped a bar to the axle so it would be easier to rotate it to get the holes to align since I used disc brakes and the jacking points were no where near the center of mass.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
