Old 02-29-2004, 02:50 PM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Axle consult
Should be picture below. What do you think? Anyone know a place in New England that does the work or is it a do it yourself.
Over59 is offline   Reply With Quote
Old 02-29-2004, 03:17 PM   #2
Over59's Avatar
Images: 37
PS
PS I know all about getting them from Andy. Just looking for caution or encouragement about doing it myself. They really do look shot..
Old 02-29-2004, 05:35 PM   #3
Post axel !
paul ....
can you tell us what we are are looking at......
thanks
paul
(newbe in florida)
p.dow is offline   Reply With Quote
Old 02-29-2004, 05:39 PM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
From the angle of the picture - it looks great.
However since we can't see the angle of the swing arm, we cannot tell if the rubber is shot.
Everyone I've ever talked to who did the replacement themselves says its not bad - just four bolts and shock + brake wires.
Ken
Ken J is offline   Reply With Quote
Old 02-29-2004, 07:21 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Ken
I can attest to that from personal experience. Only took about three hours, even with my brother helping me...
If the swing arm is pointed up towards the wheel well, the axle is bad, if it is pointed down, it is still good.
Old 02-29-2004, 09:14 PM   #6
Over59's Avatar
Images: 37
I'll have to try again with the picture. Need to move the trailer to work on it anyway. The way I figure, it cann't hurt to change the axel, can hurt to not change it if needed or nearly so. Think I'll go for the whole setup as that has to be easier than changing parts around. Besides, done see any 56 around for sale so I'll move ahead on the 68.
Old 03-01-2004, 08:53 AM   #7
PSYCHPW
The axle condition is checked by the position of the torsion arm.
Go to our web site, inlandrv.com
Click on "articles" and then click on the "Dura-torque axle."
That article teaches you how to check the axles.
Old 03-01-2004, 09:19 AM   #8
Ken J's Avatar
Durango , Colorado
Images: 14
You have a good point about replacing the axles - its not a bad idea - that way you have basically zero miles on the trailer. It gives you all new running gear, modern brakes, bearings etc.
Also a lot has been talked about the torsion angle, little about spindles breaking off - I've heard of several trailers that has happened to.
So to me, once a trailer is 25-35 years old, its not a bad plan to replace axles. Especially on a single axle trailer - it's not all that expensive - not to mention that single axles I think carry a rougher load than doubles
Ken J.
Old 03-01-2004, 01:33 PM   #9
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
I ordered new complete axles from Andy @ InlandRV last fall for our 26' Overlander. I really dreaded changing them out but the torsion arms were about dead level when unloaded. On happy Saturday Annie and I tackled the job. Once we figured out a system for lifting the new axles into place the job went off with out a hitch. Our rig is a 62 model so the original axles were all welded, plates and all. I drove camper onto a set of ramps until the rear tires lost contact with the ground. Pulled the wheels off, snipped the electric brakes, removed the nuts on the shock studs. blocked up the axle with three jacks (one under each drum and one with a three foot long channel welded to the lifting plate for the axle tube to sit in. Got the cutting torch out and cut the angle mounting plate where the axle tube was welded on both sides, then with some taps from a hammer lowered the old axle down until it cleared the trailer, then pulled it from under the trailer.
Next I fitted new shocks on the new axle and slid the new assembly under the trailer on furniture dollys. (make sure the axle is oriented right, I had to put it out and turn it around) We then put the jacks under the drums and the one in the center and started jacking the new axle up, adjusting one way or the other as it got closer to the slot where the old one came out. The new axles are so precision that if it is the slightest bit out of alignment, it's plates won't go to the inside of the original mounting brackets. Tapping at the ends of the new mounting plates one way or the other helped with the little movements needed to get it up into place, and it is a tight fit, I bet you could'nt get a piece of paper in the gap between the old bracket and the new one.
Once it was in place I finished hooking up the shock and tightening the nuts. I got my 1/2" drill out and drilled new holes in the original mounting bracket through the predrilled holes in the new axle bracket. Each side has three, the nuts and bolts were provided by Andy. Reinstalled the wheels.
Backed the trailer down, changed the ramps to the rear so the front wheels were free then repeated the whole process. After the front axle was on I reconnected the brake wires. Time for the whole process was 5 hours on the first axle - three on the second.
The difference was worth the sweat alone. Stuff riding in the rig stays in place, the trailer sits higher and the brakes are 100x better. I'm sorry I waited as long as I did.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 03-26-2004, 09:30 AM   #10
Over59's Avatar
Images: 37
Torgue Specs
Anyone know what the torque specs are for the axel and shock bolts?
Old 03-26-2004, 11:06 AM   #11
1954 25' Cruiser
Paradise , Texas
Andy would be the best person to ask. I used an electric impact wrench and the lock washers were good and flat. If I had to guess I'd say 100ft/# on the axle mounting bolts, but the shocks don't need that much, probably 40-50ft/#, I used a lock nut on the shocks.
Paul.
Paul Mayeux
AirForums #1565
WBCCI #7162
Old 03-26-2004, 11:28 AM   #12
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Re: Torgue Specs
If you can provide the bolt sizes, I have access to a torque table. I will assume they are Grade 8 fasteners.
Tom
