Old 08-23-2012, 04:37 PM   #1
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Axle condition: it ain't just the angle
I've been noticing over the past several years, people condemning the axles on Airstreams simply because the angle of the trailing arm was at zero degrees. I have repeatedly posted that is not the case, as that is the angle the axles are designed to be when mounted on the trailer, and the trailer in normal working order.
Today, I decided to kill my lunch hour by walking around the lot at the Airstream dealership where I work, and snap a few photos of axles on Airstreams in various stages of their lives to prove my case. The next several posts and photos all show the trailers at rest, empty of personal items.
First one is a 2008 Classic. This is one of the disc brake models, but the trailing arms and spindles are the same as drum brake equipped Airstreams.
ID:	166557   Click image for larger version
Old 08-23-2012, 04:40 PM   #2
Well Preserved
1993 21' Sovereign
Next is a 2009 Flying Cloud. Same angle on the trailing arms as the Classic, and the drum brakes are evident:
ID:	166559   Click image for larger version
Old 08-23-2012, 04:42 PM   #3
Well Preserved
1993 21' Sovereign
Next is a 1994 Excella 1000. Same thing, zero degrees:
ID:	166561   Click image for larger version
Old 08-23-2012, 04:45 PM   #4
Well Preserved
1993 21' Sovereign
Now I walked across the driveway to the new trailers. Here we have an Eddie Bauer model. Surely, this mondo, off-road, go anywhere, 16" tire-equipped trailer has a higher angle on the trailing arms. Uh, nope...
ID:	166563   Click image for larger version
Old 08-23-2012, 04:47 PM   #5
Well Preserved
1993 21' Sovereign
Then, there's a little 20' Flying Cloud. Maybe this one has a different starting angle on the trailing arms? Again, no.
Old 08-23-2012, 04:50 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
When I put on brand new Dexters and weighted them the angle was close to zero. I thought I was the only crazy one.
Old 08-23-2012, 04:51 PM   #7
Well Preserved
1993 21' Sovereign
Last, I walked back into the shop, where a 1970 Sovereign is waiting for new axles. I know it needs them, since the trailing arms didn't move when I jacked it up to replace the tires. Getting new tires up into the wheel wells was an adventure.
So, you would think this one would have that dreaded "up angle" on the trailing arms you hear so much about? Again, no. You can see through all the rust and cobwebs, the training arms are in almost exactly the same position as all those new and newer trailers above.
ID:	166566   Click image for larger version
Old 08-23-2012, 04:53 PM   #8
Well Preserved
1993 21' Sovereign
So, as you can see, the angle of the trailing arms really doesn't show much of anything. The only real way to tell if the axles have life left in them is to jack up the trailer (properly), and observe how much the tires drop when the load is removed.
I hope this clears things up, and reduces some confusion for anybody wondering about their axles.
Old 08-23-2012, 04:55 PM   #9
Well Preserved
1993 21' Sovereign
No, that is where a 22.5 degree starting angle should be, when the axles are loaded to their rated capacity.
Old 08-23-2012, 04:58 PM   #10
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Careful overlander63 the new Sports starting angle is 10° down, learned that the hard way.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 08-23-2012, 05:51 PM   #11
Well Preserved
1993 21' Sovereign
Greg
So the trailing arm will be pointing up when the trailer weight is on it? Good to know. There is a 22 Sport on the lot, I'll snap a couple of photos of the trailing arms tomorrow.
Old 08-23-2012, 06:31 PM   #12
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
My 67 Safari had a definite down angle to the trailing arms, unfortunatly it was frozen solid in that angle.No movement at all.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-23-2012, 06:33 PM   #13
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
overlander63,
This information is a public service to the Airstream community. I appreciate your efforts very much!!! In my opinion, if any killing was done during your lunch hour, it was certainly justifiable homicide. You'll beat the rap with nothing showing on your record except the appreciation of others.
Steve
Steve Bryant is offline   Reply With Quote
Old 08-23-2012, 07:27 PM   #14
Ottawa , ON
This is a very interesting thread, Terry, thanks much for posting it.
I must confess that I am not at all familiar with the various parts of the axle. In all the photos, I can see most prominently, a large "donut"-like thing, that I am imagining is the support for the trailing arm. I say that because if the arm was parallel to the ground, then it would not appear in the photos, and such is the case in every photo.
Can you confirm that I have the right understanding of what you are showing us? If I don't, I would appreciate your corrections.
Thanks again, Terry!
