Old 08-24-2012, 08:55 AM   #29
Originally Posted by Lumatic View Post
All seriousness aside, the arrow points to the point where the trailing arm attaches to the axle shaft.
That arrow points to the "leading" end of the torsion arm.
It also appears that the arm, as it goes rearward, is going slightly uphill.
Old 08-24-2012, 12:57 PM   #30
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Angle of the dangle arm as viewed from the rear
Originally Posted by Aage View Post
Trying again.
Is the item I point out with the red arrow the back of the trailing arm?
Yes. The big crayon arrow is pointing to the back/aft/rear end of the trailing arm. You can see to the left of the big red crayon arrow the spindle and the brake backing plate with the brake wires going into the backing plate. You can also see the spare tire in its carrier. That would lead me to believe that this photo was taken from the back of the axle looking forward.
Lance
Top is offline   Reply With Quote
Old 08-24-2012, 01:42 PM   #31
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The tongue jack and safety chains are pretty good indicators as well.
So these arms are slightly below horizontal as the trailer sits, the spindle end is lower than the torsion end. That's what we like to see, right?
— David
Old 08-24-2012, 04:40 PM   #32
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Except it is the camera angle from me crawling under the trailer. The arms are horizontal.
Old 08-24-2012, 04:46 PM   #33
Well Preserved
1993 21' Sovereign
Okay, here are the promised Sport photos. This is a 2013 Sport 22. Thanks to Greg for letting us know about this, before it bit somebody:
ID:	166646   Click image for larger version
Old 08-24-2012, 05:20 PM   #34
Central , Mississippi
Originally Posted by overlander63 View Post
So, ... The only real way to tell if the axles have life left in them is to jack up the trailer (properly), and observe how much the tires drop when the load is removed....
It seems I recall a particular case in Florida where jacking up a 31'er caused the tire/hub/trailing arm/square shaft to drop...OFF? Now who could that be?
Great work Overlander63!!!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 08-24-2012, 05:26 PM   #35
Well Preserved
1993 21' Sovereign
It worked its way out, then when the shock was removed, it slid the rest of the way out of the tube, and off the trailer. No massive hydraulic presses or liquid nitrogen involved.
Old 08-24-2012, 09:58 PM   #36
Ottawa , ON
Thanks very much, all.
Old 08-27-2012, 10:47 AM   #37
1991 25' Excella
Salt Lake City , Utah
These two pics from the factory are the best explanation I've seen showing how the "rubber meets the road" in a torsion axle. Not much of an angle seen on these particular fresh from the factory axles....
Ducatiman is offline   Reply With Quote
Old 08-27-2012, 12:33 PM   #38
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
You mean like this?
ID:	166899   Click image for larger version
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 08-27-2012, 02:29 PM   #39
Phoenix , Arizona
Flexiride makes the torsion arms adjustable with splines.
I could never understand why an axle manufacturer doesn't make the system with a steel tube insert inside a slightly larger axle tube. You could just remove a bolt (bolt would be used to keep cartridge assembly inside axle tube) and slide the old axle cartridge out and dispose of it and slide a new assembly in. If the axle was built with torsion arms like the Flexiride, then the only part to change would be the splined cartridge. There would be no more need to throw away perfectly good axles. The only part that usually goes bad is the rubber. As long as you don't spin a bearing, most of your axle components will last a long time.
M2HB is offline   Reply With Quote
Old 08-27-2012, 03:19 PM   #40
1972 27' Overlander
Denver , North Carolina
Terry,
Great work you are a phenomenal resource to newbies like me. Thanks!!
mccrosti is offline   Reply With Quote
Old 08-27-2012, 04:27 PM   #41
Those photo's were taken by me, at the Henschen plant that was in Jackson Center.
Note that the shock brackets are still not attached at least at that part of the production.
Old 08-27-2012, 04:43 PM   #42
Well Preserved
1993 21' Sovereign
Originally Posted by Greg@AirLA View Post
You mean like this?
Was that axle from that 1969 Overlander we replaced the axles on? The one where the axles disassembled themselves spontaneously?
