Old 07-04-2007, 05:07 PM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
Question Axle condition
How can I inspect to tell if my axles are in acceptable condition and how often should hub bearings be repacked? How can you tell if repacking is needed?
chuman70 is offline   Reply With Quote
Old 07-04-2007, 05:56 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Ancient forum secret
Secret to axle condition
Tom
Old 07-04-2007, 06:10 PM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Repack them now to start then every 10K with little use or 20K with heavy use.
'77 Sovereign Intl 31' CB
Old 07-05-2007, 10:11 AM   #4
Bearings should be repacked every 10,000 miles or once a year, which ever is first.
Why once a year if the trailer was not towed very much? Water (condensation) can collect in the hubs. If you don't look at the bearings, then you would have no idea if that took place.
Water in the hubs, will cause the bearings to rust. NOT GOOD.
To check your axles out, read the following article.
Dura Torque Axle
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
