Old 05-27-2012, 09:52 PM   #1
2005 28' Safari S/O
Powell Butte , Oregon
axle/brake problem
I have brand new axles 3500lb units from Axis. They came with Dexter backing plates and brake drums. When I assemble them the brake drum does not go no far enough onto the axle stub to fully cover the brake shoe, there is about 1/8 to 1/4 of an inch of brake still showing. Has anyone had this broblem before?
sawdawg1 is offline   Reply With Quote
Old 05-27-2012, 10:49 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would be contacting Axis. Are you sure the bearing races are fully seated. You should not see any part of the shoe when the drum is in it's correct position. Is the seal fully seated in the back of the hub?
Old 05-28-2012, 06:30 AM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
It takes a pretty good shove to get the inner bearing seal to go onto the final step on the spindle. I had to use the proverbial bigger hammer (a soft-faced one) to get mine to go on. Try the judicious use of force.
Old 05-28-2012, 08:38 PM   #4
2005 28' Safari S/O
brake trouble
The first thing I checked was if the race was on far enough and it looks like it is not on far enough. The race is not up against the machined shoulder of the brake drum hub. I took it apart. sanded the surfaces smoother....no luck, same thing. I took it apart and miced the hup inner dimension and compared it to the race outer dimension. There was the right amount of interface, .0001 press fit...no luck. I tried a 12 ton press...no luck. I think the problem is using an axle from one manufacturer and brake parts from another. They came as a set from a well known Airstream parts supplier in southern california, you know who I mean. I hate to take the axles out of the trailer but I guess I will and drive the 1000 miles south and find a combination of parts that will fit.
Old 05-28-2012, 09:03 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My next question is. If you bought axles from the guy down south and I think I know who you mean.
Why weren't the axles assembled and shipped as a unit with the brakes installed?
I bought Axis axles and they came fully assembled, brakes adjusted and so on.
I'd be making some serious phone calls.
Old 05-28-2012, 09:08 PM   #6
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
If it will go on far enough try pressing it on with the spindle nut. Also see if both bearings will slid all the way on the spindle when they are out of the hub. You might have a burr on the spindle not allowing the bearings to seat. John
Diesel1 is offline   Reply With Quote
Old 05-28-2012, 09:09 PM   #7
Diesel1's Avatar
1967 24' Tradewind
Does Andy now sell Axis axles? He didn't.
Old 05-29-2012, 07:50 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I bought my Axles from Inland and they came from Axis directly to my address from the factory. Fully assembled and adjusted.
Old 05-29-2012, 05:45 PM   #9
2005 28' Safari S/O
axle problem
I purchased the axles unassembled because they fit in the back of my short bed pickup easier, I guess I should have had them hang out the back as an assembled unit. I visit so cal several times a year so there wasn't a special trip.
The inner bearing slides all the way onto the axle stub, I trial assembled them without the seal in case that was the hang up but no, all three, the inner bearing, the outer bearing and the seal all fit correctly onto the axle stub. It's just a distance in and out thing. Maybe it's as simple as the axles being from Axis and the brake backing plate and drum from Dexter.
Either way I'm loading them up fpr a trip south for fathers day and will meet with the guru himself.
I emailed Andy a week or so ago but no solutions yet.
Old 05-30-2012, 08:45 PM   #10
2005 28' Safari S/O
axle problem
I tried again today without the seal getting in the way, just the beatings the brake drum does not go far enough on. So I measured the length of the axle shaft stubs, the shoulder where the inner bearing seats is .250 inched further out on the new Axis axles as compared to the old Airstream axles
Thats just enough to cover the brake shoe.
I think it's the un-combination of Axis axles and Dexter brakes.
Old 05-31-2012, 04:30 AM   #11
rogerdodger's Avatar
Fresno/Clovis , California
I am watching this post, ready to order axles. Let us know what you find out.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 05-31-2012, 06:27 AM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You may have to call Colin Hyde, he is now the exclusive distributor of Axis axles for Airstreams. EVERYone has to order through him, even those places out West.
Old 05-31-2012, 07:23 AM   #13
HowieE's Avatar
Princeton , New Jersey
Images: 12
Beginning to look like someone grabbed the wrong drums off the shelf while setting up the order.
I doubt it is a Axis/Dexter issue as drums/spindle are industry standards.
Either Axis or Dexter should be able to answer your question.
2004 Excursion 4x4
Old 06-01-2012, 07:29 AM   #14
So, you are saying Inlandrv is no longer an Axis supplier?
Roger
Air# 29488
