Old 11-05-2011, 11:47 AM   #1
1972 31' Excella 500
Ozark , Missouri
Axle Bolt torque
Let's try this again! Axles replacement question: I've got a '72 dual-axle trailer, and recently received my new axles from Andy. Any idea what the recommended torque is for the axle bolts?
Blimphauler is offline   Reply With Quote
Old 11-05-2011, 11:54 AM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
That would be a question I would ask the dealer. That information should have been in the installation instructions included with the axle. Please use grade 8 bolts and nuts with lock washers.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-05-2011, 12:09 PM   #3
Ozark , Missouri
I agree; I don't want to guess. I should have asked earlier than the day I plan on installing the axles! I got new axles, brakes, hardware (Grade 8), and shocks; all of which arrived w/o instructions, hence the perusal of past posts. At this point I think I'll get everything installed, and wait on the final torquing until I get the answer....
Old 11-05-2011, 12:21 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Dexter axles use 5/8" bolts and are torqued to 120-155 as per their chart.
Suspension Maintenance for Trailers
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-05-2011, 12:35 PM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
These bolts are in single shear; they're 5/8" grade 8 fine thread: far, far stronger than the plate to which the axles are bolted. Since the loading direction is such that the bolt threads are never subject to any dynamic load, the torque values are not critical - they just need to be good and tight.
Absent official specs, I'd oil the threads and torque to 100 ft-lbs, or as tight as you can get them with a 12" wrench absent a proper torque wrench. Torque values w/ lockwashers are always approximate - but they're required in this application as the transverse loading does tend to loosen things.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-05-2011, 12:51 PM   #6
100 to 120 foot pounds is far more than adequate.
That's for both the grade 8, 1/2 inch and 5/8 bolts.
For the shocks, just adequately tight.
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
