Old 10-04-2007, 10:33 PM   #1
1966 26' Overlander
Conover , Ohio
axle bent?
I don't know if it's a problem or not. I am rebuilding a 66 Overlander and I noticed that the axles seem to be bent slightly upward in the middle. Was it designed this way, or has someone jacked it up improperly? The wheels themselves seem vertical, so I'm not too concerned. Thanks, Tom
air66stream is offline   Reply With Quote
Old 10-05-2007, 04:12 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The axle is bent at the factory to give the wheels the proper camber. It is bent slightly upward in the middle to accomplish this.
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
bent door kcbrady Doors & Locks 3 11-28-2006 05:04 AM
Bent Wheels jim8860 Mechanics Corner - Engines, Transmission & More... 2 03-08-2006 07:17 PM
third axle bent patrick mckenzie Airstream Motorhome Forums 3 06-23-2003 05:32 AM
