Old 07-22-2016, 11:04 PM   #1
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
Axle Angles
Hi,
Trying to decide between 23 and 32 degree axles. The 32 are intriguing for better ground clearance for some of the sketchy places I might choose to drag it into, but the 23 probably ride better and have better resale.
So on an Overlander what would be a rough estimate on the difference in final height?
Thanks!
Mike
1971 Overlander Twin bed, rear bath.
2016 Ram 3500 Cummins 4x4 Crew Longbed
Thiss is offline   Reply With Quote
Old 07-22-2016, 11:13 PM   #2
1991 25' Excella
Stanfield , Oregon
They say about 2 inches higher with the 32 And the ride should be the same with either.
SpletKay06 is offline   Reply With Quote
Old 07-25-2016, 12:04 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
It would be interesting to find out how much your 45 year old trailer settled. And what the original axle angle might have been.
I would be inclined to go with the greater angle just for future drop. And it is only a feeling and not based on actual fact.
>>>>>>>>>>>>>Action
Old 07-26-2016, 12:22 AM   #4
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
Probably ordering tomorrow. The current axles have all of 5 degrees of drop at the moment. So with 32 I gain another 27 degrees, but I have no clue how that will measure out in inches. Could I see as much as 4-6 inches. I dunno.
So a higher trailer hitched to a stock height new Ram 3500 I wonder if they will be a good match of not?
I am inclined to go with the 32 just because of some serious rutted and washed out dirt roads that I use to use to get to great spots with my old Prowler that I know I can't get to with the Airstream as it currently sits.
Old 07-26-2016, 01:59 AM   #5
1991 25' Excella
Stanfield , Oregon
You'll be fine with 32's it well only raise it 2-3 inches tops. 32 degrees is the unloaded angle. What happens is the rubber hardens over time and the axles quit dropping. Basically there stuck at there loaded angle.
Old 07-26-2016, 11:52 AM   #6
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
Thanks folks. So 32 seems the way to go.
Now what about load rating. A pair of 2,800 pounders is right at my current GVWR. 3,500 would buy me a little room. I am leaving it stock and not changing a thing as far as Cabernets and Counters, layout, and my new plastic fridge is lighter than the original. I have hit the truck scales a few times while loaded and I am always right at about 5,200-5,400 when loaded for a trip with full water tank.
Do the heavier axles comprimise the ride quality? Should I just stick with the 2,800. I am not worried about having bigger brakes since my tow vehicle is well equipped to stop.
Are axle down angles correct? KYAirstream Axles 14 07-15-2016 09:27 PM
Los Angles Camping Globie64 On The Road... 17 06-11-2015 04:06 PM
Axles, Angles & Approach truckasaurus Axles 2 03-20-2014 06:02 PM
Anyone know the rollover angles? Gringo Towing, Tow Vehicles & Hitches 18 10-03-2012 03:51 PM
Axle down angles SilverHoot Axles 14 08-20-2009 06:41 PM
