Old 09-01-2012, 01:44 PM   #15
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Year of axle manufacture?
So, here's something that interests me. I've seen several posts in which people with mid-70s trailers have said that the data plate indicates that their axles were manufactured in 1970 and apparently sat around for years before being installed. I wonder if this is the source of confusion:
This is the data plate from one of my original axles, and it seems clear to me that 1970 is a date related to a patent, it's in the same font as all the pre-stamped text and different from the font of the serial number.
Unless there's some data encoded in the serial number, I don't think this plate tells me anything other than they're 2600-lb axles manufactured sometime after 1970. Does anyone know more about this?
David
Old 09-01-2012, 01:53 PM   #16
Totally wrong assumption about the date.
The 1970 means that Canada approved the Henschen design in 1970.
Old 09-01-2012, 03:16 PM   #17
DKB_SATX's Avatar
1976 Argosy 28
So between 61 and 70 Airstreams weren't approved in Canada?
David
Old 09-01-2012, 03:28 PM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It probably means that Canada changed their regulations to take place in 1970. It would have to be re-submitted for approval under the new regulations.
Old 09-01-2012, 03:41 PM   #19
DKB_SATX's Avatar
1976 Argosy 28
My actual point seems to stand, though. The only thing that year on the data plate means about my particular axles is that they were made sometime after the beginning of 1970 and unless one has info about their serial #s there is nothing to narrow it down more.
David
Old 09-01-2012, 07:59 PM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
"Armored" as in split loom corrugated covering. If not present, have at it. Split side slightly downward to drain any water, however unlikely.
Old 09-01-2012, 08:02 PM   #21
DKB_SATX's Avatar
1976 Argosy 28
So, according to Google, the patent for the version of the axle that was on my '75 trailer was issued on April Fool's Day 1969. They applied for it in 1967, so I wonder if there's some significant difference from the dura-torque axles made in the early '60s.
David
Old 09-01-2012, 08:15 PM   #22
DKB_SATX's Avatar
1976 Argosy 28
Is automotive stuff essentially the same as the stuff a nerd like me would use to organize computer or AV wiring, or is it tougher or more resistant to the elements?
David
Old 09-01-2012, 08:33 PM   #23
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
If NAPA carries it, you're good to go. I imagine there is a specialty supplier somewhere as UV plus grease/oil resistance is important. It isn't expensive, but not cheap either. The new Peterbilt I drive has every inch of element-exposed wiring fully enclosed in this manner. As do the older ones on the yard.
Someone like this company may be able to route your questions.
My ANCOR catalog is buried somewhere, but it is where I would start (as USCG ratings are always a good start). WEST MARINE carries ANCOR, but one pays for their overhead if buying in any quantity.
Old 09-02-2012, 11:01 AM   #24
DKB_SATX's Avatar
1976 Argosy 28
Do any of you with experience with both early-60s and 70s+ torsion axles know if there was a design change in the late '60s? I'm curious why the patent application for the one that covers my original axles was made in 1967. I can't imagine them having a unique design from the early '60s and not even applying for the patent until years later.
David
Old 09-02-2012, 01:19 PM   #25
Central , Mississippi
I have seen some information that indicates the internal rod (the one that fits inside the tube and is attached to the trailing arm) was changed about that time. It went from a square shape to kind of a groovy twisty shape. I also understand this design had issues with the rubber rods starting to roll up and bind.
From looking at the shape that was used in '77 (I cut apart an axle) it had the twisty shape and the rubber was all pinched up in the wedges. I got a photo around here somewhere...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
michelin, tires, axle, leaks
