Old 04-21-2010, 02:02 AM   #1
2007 27' Safari FB SE
Any where the wind blows me , California
Axle alignment on 2007 Safari
Andy,
You say that torsion axels can last 30 to 40 years "IF" properly used. If not they can fail in 3 or 4 years. What improper use would cause them to fail so soon assuming your set up properly?
Julie
jaojamjab is offline   Reply With Quote
Old 04-21-2010, 06:11 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Sitting without having a majority of weight shifted off the torsion arms.
Old 04-21-2010, 04:20 PM   #3
Originally Posted by jaojamjab View Post
Andy,
Julie
Julie.
All torsion axles have rubber rods in them. As long as the trailer is towed a few miles a couple of times a year, the axles will last a long long time.
Rubber must be exercised to stay alive. If not, the rubber can soften or harden like a rock. When a loaded torsion axle, is not used for 3 or 4 years, the rubber rods will die, from lack of use.
If the trailer will not be used for an extended period of time, it should be jacked up and supported with "jack stands". That will remove almost all the weight and stresses from the rubber rods, which will give them a fighting chance to stay alive.
The other thing that kills a torsion axle, is overloading it for an exteded period of time. If the axle is rated at 3000 pounds, as an example, long term overloading it will cause the rubber rods to fail.
That overloading can come from excessive weight in the trailer, or it's weight rating exceeded by a bad design from original production.
As an example, a 61-62 Safai used a 3600 pound torsion axle. A 63-64 Safari used a 4000 pound axle, and a 65-68 Safari used a 5000 pound axle, yet basically, they are all the same.
The changes were made because it was determined that the lower ratings were easily exceeded, causing axle failures. As a result, the weight ratings were increased in later models of the same trailer.
The same problem occurred with many early models from the Bambi's and Caravels on up to and including the 30 foot trailers.
More recently, some 34 foot models also had axles that were under rated.
When torsion axle/axles are replaced, their ratings, within limits, can be increased to eliminate the overload issues and problems. However, there is no flat rule other than do not exceed 10 to 12 percent increase from the original rating, without undertaking some beef up modifications.
Old 04-21-2010, 08:51 PM   #4
Hi Andy,
I went to an Alignment shop in Mesa recommended by an Airstream dealer there because my tires are wearing along the outside edge. I was told that they couldn't align it because my Axels were shot. I have a 2007 Safari. My running gear is balanced, I have weighed my trailer and I am under the weight limit. I have put about 20,000 miles on my trailer since I bought it new and I have had from the get go all of the problems associated with the Axels being bad. I have had the crack in the skin fixed by Jackson Center last year and It's cracked again. Do you think the Axels could be insufficient or were bad from the beginning?
Julie
Axle alignment in Oregon rustyrivet Axles 26 12-07-2008 10:35 PM
New Axle Alignment? Lumatic Axles 1 06-15-2008 06:46 PM
Axle Alignment & other service ?s dpandorf Axles 0 05-15-2008 10:58 AM
Maintenance on axle for 2007? toastie Axles 1 01-15-2007 10:55 AM
Axle Alignment Raptorrider2001 Axles 1 08-26-2003 06:20 PM
