Old 06-17-2016, 07:45 AM   #1
1963 22' Safari
Vail , Arizona
Axle alignment
I have measured the distances from the hitch nose of the trailer to the axle hubs and find they are different by 5/16 of an inch. What difference is tolerable?
Thanks in advance for any advice you can offer....
Owen as morganobenn
morganobenn is offline   Reply With Quote
Old 06-17-2016, 07:52 AM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I would want want way less, like 1/16 " ,with the curb side leading, not hard to do...
Old 06-17-2016, 09:20 AM   #3
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
It might not make any difference but I use a ball in the coupler and measure to the centre mark on the ball shank rather than the exterior of the coupler
truckasaurus is offline   Reply With Quote
Old 06-17-2016, 09:50 AM   #4
Images: 59
I think the "official" specification is 1/4". I would try for 1/8". 0" would be perfect but I'm not sure you can measure with that kind of precision.
Old 06-17-2016, 12:02 PM   #5
Tincampers's Avatar
Sneedville , Tennessee
A shop I just left said 1/16". My front axle was out 1/4" and wearing the tire. Once I backed on to the rack it took them just under an hour and $150 to fix. I highly recommend Myers Alignment in Ontario, OR.
Tincampers is offline   Reply With Quote
Old 06-17-2016, 12:19 PM   #6
Images: 59
The specification of 1/16" is for hub to hub distance between two or more axles. I agree that 1/16" from axle hub to hitch ball center would be great; I'm just not sure that is acheiveable in most cases.
The other issue is that the hitch ball socket may not be exactly on the trailer centerline.
The best way to check the axle alignment is to make sure the axles are perpendicular to the centerline. The allowable amount the axles can be off of perpendicular is 1/2.
But that is exceeding difficult to measure on a built trailer.
If you do the trig, 1/2 off is about 3/8 inch at the hub end.. In my opinion that is too much. But that's how much the axle on my Tradewind was off before it was adjusted.
I think 1/16" would be the best you could achieve without lazer interferometry.
Axle alignment on 2007 Safari jaojamjab Axles 3 04-21-2010 08:51 PM
Axle alignment in Oregon rustyrivet Axles 26 12-07-2008 10:35 PM
New Axle Alignment? Lumatic Axles 1 06-15-2008 06:46 PM
Axle Alignment & other service ?s dpandorf Axles 0 05-15-2008 10:58 AM
Axle Alignment Raptorrider2001 Axles 1 08-26-2003 06:20 PM
