Old 03-28-2012, 08:44 PM   #1
Walker , Louisiana
Axle?
I have a 77 sovereign my axles are going out.I have two trips coming combined they are about 500 miles.will it hurt using the camper I live Louisiana and we have flat ground and crappy interstates?
Treyladut is offline   Reply With Quote
Old 03-28-2012, 08:56 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Go for it as long as you have good tires and operating brakes.
Old 03-28-2012, 09:01 PM   #3
Walker , Louisiana
Tires are in fair shape and the brakes work.
Old 03-28-2012, 09:05 PM   #4
Central , Mississippi
IMHO and based on hauling a '77 with crappy axles on the same roads...
You don't have to worry about arriving home from your 500 miles with only an Airsteam tongue dragging behind your tow vehicle...
You may find a few things that say "I've been on the road"...
Last time I checked, the reason we get campers is to go camping...
Keep us posted on your adventures!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-28-2012, 09:09 PM   #5
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Before I had my axle replaced, the camper shook so bad that it sheared off a few rivets inside every time I drove. With the new axle, no missing rivets. I wondered what it was doing to the plumbing and electrical.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-28-2012, 09:23 PM   #6
Walker , Louisiana
Exclamation
How mUch do axles run? This thing is like my 77 jeep waggy I am restoring.it takes every penny but they are worth it.I got rid of a newer 5 th wheel for the silver wagon.if I could get my wife to fell same way it would be a perfect life.
Old 03-28-2012, 09:28 PM   #7
Globie64's Avatar
Images: 18
I paid about $900 to have it done- maybe $450 for the axle and the same for labor. That's for a single Dexter that matched the OEM spec, 3500gvw.
Old 03-28-2012, 09:41 PM   #8
If ya want some reading...
http://www.airforums.com/forums/f437...les-39688.html
Old 03-29-2012, 05:33 AM   #9
Walker , Louisiana
Doing the test looking At rim and fender wheel.the top of my rim is about 3" below the top trim on the fender wheel.
Old 03-29-2012, 05:42 AM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
"The Test" is not really accurate, since Airstream moved wheel well moldings up and down over the years. I've seen trailers that passed the test have really bad axles, and trailers that failed the test have good axles. All Airstreams with the 22.5 degree starting angle (all the OEM ones, even the new ones) will have the trailing arms of the axles at zero degrees when they have a load (like the trailer) on them.
A better "test" is to raise the trailer with a jack under the proper spot, and watch how far the tire drops when the weight is removed from it.
Old 03-29-2012, 06:15 AM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Terry nailed it!!
It's the angle of the dangle, if it drops a little go for it, if it don't, go for it anyway, drive carefully and be prepared for some loose rivets.
We toad several Seasons with a bad axle on our 63 with nothing more serious than a few looseies.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-29-2012, 06:39 AM   #12
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The axle on my Bambi II is also pretty shot. It tows just fine, but a little harsh. Fixing that tomorrow with a new axle from Colin Hyde. Axle price is $495 with shipping cost of $225 to a commercial address.The axle comes completely assembled & include 10" brakes, powder coated axle tube, "safety lube" spindles (allows you to grease the bearings without removing the wheels), shock brackets welded in place, mounting bolts, lug nuts & an owners manual. The shop doing the work has done several Airstream axles and seemed very knowledgeable about Airstreams when I spoke to them. They thought it was funny when I told them how much some shops were charging for the job. Installation is $150, two hours labor. Easy job when you have the proper tools and knowledge. It will be nice to have a softer ride with working brakes.
MICHAEL
Old 03-29-2012, 03:24 PM   #13
Walker , Louisiana
What is the proper way to jack it up and test the axles?
Old 03-29-2012, 03:40 PM   #14
No jacking necessary.
Pull one tire at a time up on some 2 X 6's.
Then observe the tire drop.
Dexter Axle replacement ljmorr3 Axles 17 03-29-2013 01:42 PM
Axle replacement Dan S All Argosy Trailers 46 04-27-2012 12:36 AM
New to the big leagues (first triple axle) Alden Miller 1990 - 1993 Excella 17 04-03-2012 11:06 AM
Restore or replace leaf spring axle? silverwoman Axles 7 03-29-2012 08:33 PM
1987 Airstream Excella 35' Triple Axle eBay Watch Airstreams on eBay 0 03-27-2012 08:20 AM
