Old 03-20-2011, 09:28 AM   #1
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Axis grease seals?
Hi,
Does anybody know what size dust seals I have on my Axis 3500# axles/wheels? I want to get the seals before I repack the bearings.
Thanks.
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
Old 03-20-2011, 09:42 AM   #2
Originally Posted by seldencove View Post
Hi,
Thanks.
What size brakes does your axle/axles have?
Old 03-20-2011, 10:20 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Hi,
Thanks.
Axis part #766251254800, DL 350 seal, 2.561" bore, 1.719" shaft.
Colin
Colin H is offline   Reply With Quote
Old 03-21-2011, 06:16 PM   #4
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Thanks Colin,
I went to Napa today and picked them up, all set to go....Andy, I think I have 10" brakes, not quite sure yet until I pull them apart.
Mark
Old 03-21-2011, 06:29 PM   #5
Thanks Colin,
Mark
No need to take anything apart.
The brakes are mounted to a flange that's welded to the spindle.
If that flange is square, then you have 10 inch brakes.
If the flange is round, you have 12 inch brakes.
Your trailer originally had 12 inch brakes, which of course has much more stopping power than 10 inch brakes, if yours are so equipped.
Old 03-29-2011, 09:09 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
And if you properly maintain those 10" brakes your Excursion will have won't even know it's back there.
>>>Action
Old 04-03-2011, 06:57 AM   #7
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
As it turns out, I have a B12E hub with 12 " brakes, 2.125" inner bore and 3.375" outer, DL600 seal, bearing 25580 inner and 15123 outer.
Window seals and clips for '66-'67 globetrotters Alderman 1965 - 1969 Globetrotter 10 10-16-2014 07:16 PM
Weather stripping aluminomad 1966 - 1968 Safari 22 11-06-2011 12:49 PM
Seals For Wheel Bearings ~ 1958 Pacer Ariz-Pacer Wheels, Hubs & Bearings 9 03-22-2011 10:50 PM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
