Old 03-30-2012, 10:41 AM   #1
1961 24' Tradewind
Burlington , Vermont
Axis Axle Problems?
HI,
I've used a 3,500lb Axis on a 66 Caravel and loved it so I put a 5K Axis on my rebuilt 61 Tradewind. After about 10k I noticed one tire was waring the inside tread off. Should have called the co but thought it was the bias tires. Shifted to radials and didn't travel much for 2 yrs, but this year during a trip it is still wearing weird. Sent pics to Axis and turns out the axle is bent. Must have been out of the factory that way but you wouldn't notice because it is only about 1/8" difference in clearance top & bottom. By this time the warranty is gone but before I invest in a new one just wondering if anyone else has had this problem with new Axis axles? Tks.
Mica is offline   Reply With Quote
Old 03-30-2012, 12:20 PM   #2
Originally Posted by Mica View Post
HI,
In defense of every manufacturer of anything that must be shipped via motor freight, they cannot be held responsible for anything, once the freight company accepts the product in good condition, which they do when they sign for it.
All torsion axles tubes are bent, so to speak, since that is how they are aligned.
I would suggest that you check the complete alignment of the axle, both in exactly where it's mounted, and within itself.
Out of alignment axles, can be easily realigned to original specs. Not many places can do it, but it is done.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-31-2012, 07:08 PM   #3
1961 24' Tradewind
Axis Axle Problems
Thanks Andy,
It may have been damaged in shipping - it is not an alignment problem - the company spokesman looked at the pictures I sent and said that the, "...inner bar that presses into the tube is bent. the gap at the bottom is larger than the gap at the top." Apparently even 1/16th difference will result in wear. I wore all the tread of the inside half of the SS tire in 10k miles. Anyhow, guess it is a new axle but I was wondering how rare this is given the durability of the original axels.
Old 03-31-2012, 07:27 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
As Andy says, have the alignment checked at a shop that does trailer axles. I replaced the axles on both of our Airstreams. They were from two different manufacturers, and both trailers were out of alignment and had odd tire wear with the new axles. The shop will have to have the old style alignment pit rather than a "drive on" setup. A good shop will back the trailer onto the alignment equipment and align the axle to the tongue, so that the trailer goes straight behind the tow vehicle. On a duel axle trailer, they will align the front axle to the tongue, then align the rear axle to the front axle, again making the trailer tow straight behind the tow vehicle.
Get them checked and aligned if necessary.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 04-03-2012, 04:17 AM   #5
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
If close enough, take a trip over to the Mothership and see if the can do it for a small,price - factory perfect...
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Axle? Treyladut Axles 23 03-31-2012 02:48 PM
used rv AIRSTREAM 345 MOTORHOME ALUMINUM COMPLETE TAG AXLE CLASSIC RARE LOADED Sused eBay Watch Airstreams on eBay 0 03-29-2012 09:10 PM
Restore or replace leaf spring axle? silverwoman Axles 7 03-29-2012 08:33 PM
1987 Airstream Excella 35' Triple Axle eBay Watch Airstreams on eBay 0 03-27-2012 08:20 AM
