Old 03-26-2006, 08:11 PM   #1
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Axis Axle problem resolved
Some of you may remember from a previous thread that I had a problem with a pair of axles that I got from Axis last November. Here's a copy of that message from Nov. 20, 2005:
I picked up a pair of new axles from Axis a couple of weeks ago but due to the weather and other commitments I didn't get around to installing them until today. When I looked at them I realized that the new axles are not the same as the old ones.
The brackets appear to have been put on the wrong ends so they extend more to the back, but on the old axles the brackets are longer to the front of the axle.
The distance between the brackets is 1/8" greater on the new axles. The brackets on the axles have to fit between the axle mounts on the trailer and since the old axles were a tight fit I think this extra 1/8" would make it very hard to get the axles into place.
The distance between the mounting plates for the brakes is 3/4" less on the new axles, which I think means the tires would be 3/4" closer together.
How could they get this so wrong when they had the old axles to copy from? I'm glad I brought the old axles home, but I wish I'd looked at the new ones more closely when I picked them up.
I'll be calling them tomorrow to see how they can fix this problem.
After several phone calls to Chad at Axis I received a pair of new axles just after Christmas. One of them was fine, the other had a different angle on one end. Also the axles came with taxes and brokerage fees owing because they had been shipped across the border. I picked up the first pair and because I brought them across the border myself there was no tax to be paid. A few weeks after another call to Chad I received another axle that was correct, along with another bill for taxes and brokerage fees on that axle.
I faxed the receipts for the taxes and brokerage fees to Axis and recieved a check for the full amount last week.
The axles have been installed and after a trip to Myrtle Beach and back I'd say they appear to be fine. I haven't put the shocks on yet. When you install axles outside in February in our area you don't do any more than you have to!
The trailer sits about 2" higher measured at a point between the axles and now it looks level. Before the rear end was definitely lower than the front.
After 5 axles and 4 months we're back on the road.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 03-26-2006, 08:15 PM   #2
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Glad to see it worked out for you in the end. Glitches happen sometimes. When they happen too much, then you need to be worried. Based on everything I've read on this forum, when it comes time to replace the axles on my Sovereign, I'm going with Axis.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 11:05 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 06:40 AM
Axle Offset Question DanLyle Axles 11 08-28-2002 10:35 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
