Old 06-08-2016, 08:06 PM   #15
Tincampers's Avatar
Sneedville , Tennessee
Originally Posted by tjdonahoe View Post
I use a jack on the subframe with a 6" long 1/2 thick flat iron on the top of the bottle jack, no problems.....
What are you pushing against? Mine is toed in so it will have to be pulled back into alignment.
Tincampers is offline   Reply With Quote
Old 06-09-2016, 05:50 AM   #16
Native143's Avatar
2013 20' Flying Cloud
Dunedin , Florida
Originally Posted by Rpatrick16 View Post
Are there any evidences on the tire walls to indicate you've hit an object like a deep pot hole etc? It's a 2014...any warranty left on it? Wish I could offer more help but the questions that I posed above should help build your case that it wasn't abused.
Except for bumpy campground roads there has been no strenuous conditions. 2014 bought Dec. 2014 so good for another 6 months. Dealer says they dont cover it but I will take it up with Airstream or Dexter axles.
Native143 is offline   Reply With Quote
Old 06-09-2016, 05:59 AM   #17
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Used to jack up in order to rotate tires, Not to straighten a bent axle....
Old 06-09-2016, 06:25 AM   #18
Tincampers's Avatar
Oh, I misread what you posted. Thought you had used it to bend the axle.
To Dealer or not to Dealer, that is the question Johnsito Brakes & Brake Controllers 7 07-27-2013 09:11 PM
Tire dealer says... AIR-Quarius Tires 13 02-14-2013 07:07 PM
Dealer says why remove clearcoat...it's bad cutterbug General Repair Forum 3 04-21-2009 06:45 PM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
axle bent? air66stream Axles 1 10-05-2007 04:12 AM
