Old 06-22-2009, 06:17 AM   #1
AxelBruijnis's Avatar
1978 31' Sovereign
Gasselternijveen , drenthe
Send a message via AIM to AxelBruijnis
are these axles still usable ?
hi airstreamers !,
Our 1986 excella 32 has its original 4000 lbs axles , arms horizontal , maybe even angled up .. slightly .
Would you still use these on a 2000 mile trip, or can i delay the replacement of the axles for a year or more ?
( i don't want to look for popped rivets after the trip )
when the trailer is horizantal , the hitch sits at 18 inch from the ground and there is approx 3 inch rubber visible between the top of the rim and the bottom of the aluminium visible , trailer loaded
thanks !
Axel
ID:	82734   Click image for larger version
1978 Sovereign 31 Mid Bath
1969 Overlander 27
2000 dodge 2500 diesel
AxelBruijnis is offline   Reply With Quote
Old 06-22-2009, 06:36 AM   #2
richinny's Avatar
2011 34' Classic
how to check them:
Dura Torque Axle
Ricky
Old 06-22-2009, 06:45 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
They look OK to me. The problem axles seem to be more the early 70s.
If they are shot the the risk is damage from vibration over a long period of time, not sudden catastrophic failure. Besides the torsion arm position jack up the axles and make sure the wheels drop in the wheel well at least 2-3", staying in contact with the ground, before they come off the ground.
Old 06-22-2009, 07:43 AM   #4
1978 31' Sovereign
the test result
Originally Posted by richinny View Post
how to check them:
Dura Torque Axle
I just measured, the wheels drops 2.1 inch when jacked up, just before leaving the ground.
Axel
1969 Overlander 27
Old 06-22-2009, 08:08 AM   #5
richinny's Avatar
2011 34' Classic
Axel
"Another test is to jack up one side of the trailer. The tire or tires should drop at least 3 inches. If not, then the rubber rods have solidified. When the rods have solidified, the cushioning of the axle becomes nil, which causes the trailer to bottom out, when hitting bumps."
so, it seems they need replacing. at least they had some movement.
Ricky
Old 06-22-2009, 08:42 AM   #6
hi airstreamers !,
thanks !
Axel
Axel.
The off the production line ball height for your Airstream was 18 3/4 inches.
Make your trip and check the axles again when you return.
More information is available in an article that's in the Airstream Central web site.
Old 06-22-2009, 10:30 AM   #7
Central , Mississippi
Axel
Here is what mine looked like before I replaced them. The rear axle is on a 4" ramp and the front axle is 1" off the ground. My trailer had about the same ride height as yours so I was in no hurry to replace the axles until the interior started showing problems from the rough ride - walls moving, brackets breaking...
After the axle replacement the 4" ramp is barely tall enough to get the other axle to clear the ground if the trailer is lightly loaded.
I would have skipped the axle swap if we didn't use our trailer on a monthly basis averaging +5,000 miles a year.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
angle, axle, excella
New Axles LHall Axles 4 08-09-2007 01:17 PM
Do I need new axles? Barbara Peerenboom Axles 11 12-19-2005 10:48 AM
Axles and such... Anon Axles 60 06-11-2005 01:26 PM
Do these axles look OK? 66Overlander Axles 11 10-22-2004 06:27 AM
Do I need Axles??? blucloud Axles 3 08-16-2004 06:23 PM
