Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 03-17-2017, 01:04 PM   #1
1986 32' Limited
bayville , New Jersey
Are my axles good?
We have an 86 limited, just traveled from NJ to FL then west on Rt10 (rough) nothing moved out of place, even apples in a bowl on the table were still on place, think my axles might be ok?
bunlacken is offline   Reply With Quote
Old 09-14-2017, 06:14 AM   #2
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
so did you ever figure out if axles OK.. not sure apples in bowl on table is the final answer more likely the axle arm movement unloaded and loaded..
just askin..
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Axles: Dexter, Leaf Springs, Coil Springs, Straight Axles Ray Eklund Axles 22 09-10-2016 06:02 PM
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Axles-Good-Bad-Just Passing?? rogerdodger Axles 15 01-01-2009 10:30 AM
