Old 02-19-2008, 07:41 AM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The rear axle tube bend was designed into the axle tube. The front axle tube should have a similar bend.
The rest of the axle riding charistics look good. And 30+ years for a torsion axle is a good amount of time. Take your trailer out frequently this will flex the rubber rods inside the axle and be good for extending the life of the rods that are the springs in the axles.
Nice looking trailer on the outside.
>>>>>>>>>>>Action
Old 02-21-2008, 01:48 PM   #16
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
I have the A/S over at Bob Jones RV here in Houston for some other minor issues and they are going to give me their opinion on the axles.
Don
adonh is offline   Reply With Quote
Old 02-21-2008, 05:26 PM   #17
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Divine Axelvention
Originally Posted by adonh
The angel on the spindle arm is still slightly pointed down on both.
I would like an axle angel please. Where can I get one?
Lumatic is online now   Reply With Quote
Old 02-29-2008, 01:54 PM   #18
adonh's Avatar
1976 31' Sovereign
Theres still life in these old axles
Just spoke to Chris Jones at Bob Jones RV and they feel the axles are still good on my 1976 31' Sovereign. So for now I am going to have the bearings and brakes checked and check the balance on my tires and check this again next year. When I do replace them Chris recommends the Henschen axle. So Andy I am starting to save my now so that I will be ready.
Don Hardman
Old 02-29-2008, 04:24 PM   #19
Don Hardman
Don.
Please have Chris check the tire drop.
Have him jack up one side of the trailer, and see how much "more" the tire drops, until it's off the ground.
It should drop about 2 to 3 inches.
If not, then the rubber rods have solidified, which will give the trailer a rough ride.
Generally speaking, if a load has been placed on a torsion axle, for several years, but has not been exercized, then the rubber rods can solidify.
There are two tests. In your case, there is plenty of tire above the wheel. So your axles are OK there. But the tires must also drop when the trailer is lifted off the ground on one side. If they do drop that 2 to 3 inches then your axles are in very good shape.
If they only drop an inch or less, then the rubber rods have solidified, making the axle give the trailer a rough ride. Not good.
Old 02-29-2008, 04:53 PM   #20
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Don.
Generally speaking, if a load has been placed on a torsion axle, for several years, but has not been exorcised, then the rubber rods can solidify.
Andy, can you please clarify something. In the "drop test" would it work the same if the trailer was ran up on two ramps so one axle is free to fully hang down. Or, is it critical to do the test running one wheel on one side up to check the drop of the other axle? Thanks....
Old 02-29-2008, 05:31 PM   #21
If you have a single axle trailer, it doesn't matter.
If you have a tandem or triaxle trailer, jacking up one side of the trailer will let you check all the axles at one time.
Bad axles, rough road, bent frame Lumatic Axles 0 05-21-2007 08:24 PM
Pictures of our bad axles Buttercup Axles 9 06-08-2005 06:22 AM
Bad axles Inland RV Center, In Axles 48 06-30-2004 09:40 AM
Are My Axles Bad? trogers713 Axles 48 05-07-2004 07:47 PM
Axles, how do I know if mine are bad? nds Axles 16 12-19-2003 02:32 AM
