Originally Posted by Marshall I assume if you got the axles from Andy they are Henshels? Did you have to make any changes to the height of the hitch ball to compensate for the higher set of the trailer? |
Replacement Henschen torsion axles from us, usually requires adjusting the ball height, if the previous rigging had the trailer and tow vehicle level with respect to each other.
Further, because of todays higher profile tow vehicles, we increase the starting angle to not only raise the trailer even higher than when new, but to also minimize the need for drop shank hitch bars, which makes hooking the trailer up to the tow vehicle, easier.
