Old 10-10-2006, 03:15 PM   #1
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
Question Another axle question
Someone mentioned that if a AS sat a long time but was up on trailer jacks that it was less likely that the axles would be bad.
Is that true; and why would that be so?
wannaroam is offline   Reply With Quote
Old 10-10-2006, 03:53 PM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Arrow Reply to Another axle question
Hey Wannaroam; The answer is rather simple. I you have something that you do not use a lot, it tends to last longer. Because the torsion arm suspension has rubber hub insde the square axle tube, in which a square shaft of a torsion arm is pressed into under specific conditions with the help of great ammount of pressure. This rubber hub acts as a dampener for the torsion arm. When a continious weight is applied to the arm it simply deforms quicker from constant pressure on the hub. It is true that axle will last longer if you keep the weight off of it during long storage period, while you keep the rust and moisture away from it.
Hope this helps you to understand the reason for someone's statement in respect to the axle.
Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 10-10-2006, 04:37 PM   #3
wannaroam's Avatar
Images: 36
Boatdoc
Thank you. I wondered why the jacks made a difference. So it is not just the sitting stationary for a long time; but the sitting on the axles for a long time.
Ok, I get it!
By the way, do you ever do any inspections for people?? I am near Pittsburgh and many of the units I've looked at are 2-3 hours from here (usually east).
Old 10-10-2006, 06:00 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Actually the best thing for a torsion axle is to use it. It keeps the rubber compounds "active". I don't know if it would get a set by having the load off of it or not. I do know they will get a set if you leave them sitting for an extended length of time. FWIW my 80 axles are toast, they are negative and there is almost no interior in it. My 75 the axles are still slightly positive. They will need to be replaced, but not right away. I know for a fact that the 75 was towed a lot in it's earlier years. From what little history I have of the 80 it spent most of it's time sitting in a RV park only getting moved once or twice a year, if that.
Aaron
WBCCI #XXXX AIR #2495
Old 10-10-2006, 06:36 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
My experience has been that the axle's rubber rods will harden over time, regardless if there's a load on them or not.
My 63 had a positive angle on the torsion arms (pointing down) , but literally no suspension. Other trailers that I have been around had level or negative torsion arms, but had still soft suspension.
I'd say, if there is doubt, buy new axles.
Uwe
www.area63productions.com
Old 10-10-2006, 07:49 PM   #6
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Howzat?
How can you tell if you have suspension left, if you have a flat or negative angle on the arms?
Adding weight? Trying to "bounce" it?
Since I have a barely positive angle, it would be nice to know if there is any "umph" left and I can pull it for a bit without rattling the rivets too much.
While I am saving up for new axles.
thanks, bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 10-10-2006, 07:56 PM   #7
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
thanks, bill b.
This is a hard questio to answer. My trailers with good or new axles always had a pronounced bounce to them when standing inside and bouncing the floor with your legs without jumping.
The torsion arms are the short arms that lay in the direction of travel, extending from the axle tube backwards to the spindles.
If the arms point down, even slightly, with a loaded trailer, then that's initlally a good sign.
If the arms are level, or pointing upwards, thatn initially that is a poor sign.
However, the remaining rubber quality is what makes the biggest difference, in my opinion. If there is good and soft suspension, then the axles should be fine for a while longer.
If the torsion arms point drastically down, like 5-10 degrees or more, then more than likely the axle is shot, and needs immediate replacement.
Uwe
Old 10-10-2006, 08:29 PM   #8
wannaroam's Avatar
Images: 36
For someone who still isn't sure that they are "getting it", could someone post a picture with an arrow pointing to the tortion arm?
Old 10-10-2006, 08:40 PM   #9
The torsion arm i sthe heavy metal casting that goes from the square shaft to the brake flange.
Old 10-11-2006, 07:05 AM   #10
wannaroam's Avatar
Images: 36
Ok, square shaft to brake flange,......ah, I'm a bit testosterone challenged here.
Is this correct?
Old 10-11-2006, 07:42 AM   #11
Somewhere , Indiana
Yep!
Aaron
This retired axleman will second that!
Regards,
Henry
axleman is offline   Reply With Quote
Old 10-11-2006, 08:29 AM   #12
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Can these torsion arms be rebuilt?
'77 Sovereign Intl 31' CB
Old 10-11-2006, 09:06 AM   #13
Somewhere , Indiana
Yep!
YES!!!
Regards,
Henry
Old 10-11-2006, 09:06 AM   #14
Axle rebuild
Years ago, torsion axles were commonly rebuilt by replacing the rubber rods.
Torsion axles manufacturers are no longer willing to do that because of liabilty.
All too many times, the inside of the square shaft was found to be very rusty.
Adding new stresses to the weakened square tube was deemed not a wise decision.
Calling the customer and advising them of the problem, caused ethic and honesty questions, such as "how do I know your telling me the truth."
Therefore torsion axles are no longer "rebuilt," under any circumstances.
Tow Vehicle Question-for a 34 ft, 3 axle Excella dmreilly10000 Tow Vehicles 26 08-02-2011 09:05 PM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
