I have a 1965Caravel. The torsion type axle was replaced due to an accident. The installer saie that he aligned the axel. I am getting way too much wear on the inside of the tires. Using a tape measure and a level I have found zero tow-in and about six degrees of negative camber on each side which I believe may be causing the excessive wear on the inside of the tires. Anyone know the numbers?
Oh, as for alignment, I don't know why a trailer axle would have negative camber, unless it was 'flipped' or installed upside down. What type of axle is it? If it's a torsion type, I don't know, but Dexter leaf spring axles come with positive camber built in.
