Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 09-22-2006, 01:27 PM   #1
The Hairstream
LadayLuc777's Avatar
1975 31' Sovereign
Salinas , California
Airstream Virgin needs a bit of help
Hello to all
I just got a 75 31' airstream T/T and i would like someone to look at my axles and give your best advice ... I'm in Salinas Ca thanks
Georgio Contrer
LadayLuc777 is offline   Reply With Quote
Old 09-22-2006, 01:43 PM   #2
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Hard to say from the angle of your photo, but it looks like they are slightly "up," which is bad. Jack it up and see how much the swing arm swings down. Take a photo aligned with the axle tube towards the wheels, low, so the angle of the swing arms can be seen, both sitting loaded and jacked up.
Zep
Zep@Charmedquark.net
Old 09-22-2006, 01:51 PM   #3
myoung's Avatar
Nipomo , California
Images: 24
George,
Come to the rally at Lake San Antonio in October and you'll probably find all the advice and commentary you'd like. Should be an easy trip for you. Just down the road a bit.
Here's a link to the rally page:
http://www.airforums.com/forum...-20;&e=255&c=1
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion"
BMW X3 xDrive 28D
myoung is offline   Reply With Quote
Old 09-22-2006, 07:58 PM   #4
Originally Posted by LadayLuc777
Hell to all
It appears that the torsions arms, as they go rearward, are going uphill.
If thats the case then the axles are "done".
You can quickly learn how to check them out yourself, by reading the following article.
http://www.inlandrv.com/articles/dur...axle-92001.htm
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-26-2006, 02:28 PM   #5
The Hairstream
1975 31' Sovereign
Thanks for the reply - I just might go to the rally - My stream is still underconstruction - since im a newbie i got to make some friends to catch up with you folks on everything airstream --- so see ya there!! I should bring some Chees and Wine - George
Georgio Contrer
Old 09-26-2006, 02:31 PM   #6
The Hairstream
1975 31' Sovereign
Andy thanks I will read all of that info.. I think your a sharp dude I've read some of your other comments and they are sound and just good advice
thanks George form Salinas
Georgio Contrer
Airstream Virgin | Could use some advice! warrenivan Classic Motorhomes 49 05-08-2011 07:50 AM
Airstream Virgin nd48463 Member Introductions 13 09-22-2008 09:56 AM
Virgin Airstreamer- Just bought 76 Sovereign 31 rphdiego Member Introductions 11 03-24-2008 06:34 AM
Virgin! abridges01 Member Introductions 11 08-10-2006 12:01 AM
Airstream Virgin BenjaminA Member Introductions 9 05-16-2006 05:48 PM
