Old 10-29-2003, 04:55 PM   #1
nevisstudio's Avatar
Images: 8
airbag suspension
need some insight....
i have a single axle 22' 1963 safari
i want to put an airbag system on the axle so i can lower the trailer as low as possible for a wheelchair ramp.....
any advice or input would b greatly appreciated....
thanks
rich
nevisstudio is offline   Reply With Quote
Old 10-29-2003, 05:29 PM   #2
Making a Henschen axle equipped Airstream raise and lower would be a monumental task, if not impossible.
It would be much easier, by far, to have a platform to raise and lower at the entrance door.
You could do that with air, hydraulics or electrically, or a combination of those.
Old 10-29-2003, 07:48 PM   #3
LOST , Hawaii
Either way you will need to do a lot of reinforcing on the frame. If you use air bags it is going to also need a different axle with a lot of drop in order to get the trailer to drop just a few inches. This will also reduce clearance to the road. The axle is going to need to be located front to back and side to side, at least 3 points. The top air bag supports will have to tie into the main rails and nearest cross members. All these areas will have to be well reinforced.
A lift will require a lot of reinforcing to distribute the weight of the lift, chair, and occupant. These will be probably be 2-3 feet from the attaching point. Leverage and the total weight are going to overload what the frame was designed for. The weight should probably be distributed over several feet of the frame rail as opposed to just the width of the lift. Neither is impossible but both will need some careful planning.
Search for axle replacement and you will find some pictures of the Henschen axle and mounting and why it won't work with air bags.
Look at this thread and this thread. There are some good pictures which will help you understand how the frame is built.
John
74Argosy24MH is offline   Reply With Quote
P-30 suspension upgrades ??? donnall Airstream Motorhome Forums 3 11-24-2003 10:30 PM
Independent Suspension on an AS? LittleRadio Our Community 4 07-07-2003 09:41 PM
Rear Airbag Donald B Graves Airstream Motorhome Forums 9 03-15-2003 07:03 AM
Replacement air bags on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 08:42 AM
2002 Classic 25' suspension? Kistler 2001 - 2005 Classic 7 11-12-2002 01:01 PM
