Old 08-08-2010, 05:15 PM   #1
1971 29' Ambassador
South Weber , Utah
Air Springs for airsteam?
Anyone tried to put air springs under a 70's airstream. Looks like some of the heavyduty truck upgrades should fit and compensate for drooping axles. Looks like about 3 inches of height gain.
fisherjdou is offline   Reply With Quote
Old 08-08-2010, 05:21 PM   #2
Yes it's been done, but with a 100 percent failure.
Old 08-09-2010, 08:34 PM   #3
1971 29' Ambassador
South Weber , Utah
Facinating! Any idea what the root cause of the failures was? I saw where someone tried to put air shocks on and when they pumped up the pressure the failed the shock attachnments because they were not designed to hold significan percent of the load...only dampen motion. My inquery pertains to the after market "air springs" used to replace or augment heavy duty truck leafs. Seen some show hot rod trucks with pure airspring suspensions as well. Is there a load or geometry issue or negative interaction between the torsion system and springs?
Old 08-11-2010, 06:46 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
It would be difficult to attach an airspring assembly on the trosion axle of an Airstream trailer. The pre-62 leaf springs is another matter and should be rather easy.
>>>>>>>>>>Action
Old 10-03-2010, 05:21 PM   #5
1977 31' Sovereign
2005 30' Safari
North Port , Florida
We should be doing this next year to one of our trailers. We'll post the progress once we start
cliffcharb is offline   Reply With Quote
'77 Argosy motorhome coil springs air bag help. Bugler Argosy Motorhomes 0 09-21-2009 03:39 PM
Front Air bag or Springs? Don Landis Mechanics Corner - Engines, Transmission & More... 3 08-30-2009 06:55 PM
Adding air springs to a LY gas 350XL myfirstrv Mechanics Corner - Engines, Transmission & More... 3 08-18-2009 05:51 PM
Air Bags In the front coil springs spat61 Land Yacht/Legacy Motorhomes 5 10-25-2007 07:10 PM
air lift assist for front springs jagcb750 Classic Motorhomes 8 09-03-2007 07:21 PM
